path: root/arch/arm/dts/keystone-k2e-evm-u-boot.dtsi
2019-10-24ARM: DTS: keystone: complete the description of the USB PHY devicesJean-Jacques Hiblot
As the PHY driver now handles the transitions of USB power domain, we must add this information in the node of each PHY. Also, the phy are expected in the "phys" property, not "usb-phys". Also add the aliases for the USB ports on boards with more than a single port. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-07-10ARM: dts: keystone-k2e-evm: Add U-boot specific dtsi fileCooper Jr., Franklin
With Davinci I2C switching to device model, K2E requires U-boot specific device tree entries. This is only required for I2C 1 which is needed extremely early during the boot process. Fixes: 1743d040b1df ("ARM: keystone: Enable DM_I2C by default") Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
