The ICSSG IP on AM65x SoCs have two Industrial Ethernet Peripherals (IEPs)
to manage/generate Industrial Ethernet functions such as time stamping.
Each IEP sub-module is sourced from an internal clock mux that can be
sourced from either of the IP instance's ICSSG_IEP_GCLK or ICSSG_ICLK.
Add the IEP nodes for all the ICSSG instances.
Signed-off-by: MD Danish Anwar <danishanwar@ti.com>
There are a few missing registers ranges in the udmap nodes
need to properly setup DMA for the am65x.
A fix has been added to the Linux kernel [0] to add these ranges and
merged. To keep DMA operational until the next DT sync from Linux, these
ranges were added to the *-u-boot.dtsi in the upstream u-boot [1].
Porting these DMA changes to ti-u-boot as these are needed for ICSSG
Ethernet driver to work.
And additional config register was added to the ringacc node in upstream
u-boot as part of DT sync from linux 6.7-rc1 [2]. Porting those changes
as well to ti-u-boot as those are also needed for ICSSG Ethernet driver to
work.
[0] https://lore.kernel.org/r/20231213135138.929517-2-vigneshr@ti.com
[1] https://source.denx.de/u-boot/u-boot/-/commit/5e00547e583f6d4349f3908d3491bf6ce0a8818c
[2] https://source.denx.de/u-boot/u-boot/-/commit/4dbdc84754ea2ad392ef7328da6d429cd8fd3c0a
This resyncs the dts files for all of the currently in-tree K3
platforms, along with relevant bindings, with the v5.14 Linux Kernel
release. Of note are that the main-navss/mcu-navss nodes were renamed
to main_navss / mcu_navss and so the u-boot.dtsi files needed to be
updated to match.
Tested on j721e_evm and am65x_evm.
Add the DT nodes for the ICSSG0, ICSSG1 and ICSSG2 processor subsystems
that are present on the K3 AM65x SoCs. The three ICSSGs are identical
to each other for the most part, with the ICSSG2 supporting slightly
enhanced features for supporting SGMII PRU Ethernet. Each ICSSG instance
is represented by a PRUSS subsystem node. These nodes are enabled by
default.
DT nodes are fetch from Linux 5.13 Kernel.
Link: https://lore.kernel.org/r/20210622063431.3151-5-lokeshvutla@ti.com
Sync all AM65 related v5.11-rc6 Linux kernel dts into U-Boot.
Add the appropriate itapdly and clkbuf-sel values required for
some lower speed modes.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Because of fundamental interface issues in am65x pg1, only the
initial sdhci1 node at 25 MHz was added in the u-boot.dtsi
from which both the base-board.dts and r5-base-board.dts
inherit the node. Move the node out to k3-am65-main.dtsi
where it belongs and add the board specific properties
in base-board.dts and r5-base-board.dts
This ensures dts compatibility with the kernel dts in the
base-board.dts and enables the SD card interface at 50 MHz
and High Speed mode
While we are here, also fix the main_mmc0_pins_default
property to be included and inherit from the base-board.dts
instead of the u-boot.dtsi
With the latest RIOT, there is a different otap delay value for each
speed mode. Add a new binding with every supported speed mode. Also
disable a given speed mode in the host caps if its corresponding
otap-del-sel is not present.
Add support for USB0 and USB1 instances on the AM6 SoC.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Add needed device-tree nodes to support PCIe 0
and SERDES on AM65x SoC. The nodes are kept
disabled by default.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Update the power-domain-cells to 2 and add the permissions
to each node. Mark the following nodes accessed by r5 as shared:
- DDR node
- main uart 0
Add I2C DT nodes
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Only U-Boot specifc DT properties or overrides, must be in -u-boot.dtsi.
Pinctrl nodes does not belong here. Now that pinctrl nodes are in kernel
DT, there is no reason to be keep these in -u-boot.dtsi. Move them to
proper places so that it would ease copying DT entries from kernel DT.
Sync the sdhci0 node from kernel. This changes the compatible that is
required to be there in the driver. Change the same for the SD card node
which is not yet supported in kernel. This also syncs the main_pmx0 node
as a side effect.
Also change the name of the driver to match the compatible in kernel.
Sync the k3-am654 specific dts files from Linux next with tag
20181019. This changes are in queue for Linux v4.20-rc1
Add initial DT support for AM654 EVM that runs on A53.
