path: root/arch/arm/dts/imxrt1050.dtsi
2022-11-08imxrt1050: synchronise device tree with linuxMarcel Ziswiler
Synchronise device tree with linux v6.1-rc3. Note: Nowadays, the intent is for them regular device trees to just be synchronised from them Linux kernel device trees and any and all U-Boot specific changes need to go into the -u-boot.dtsi device tree include files which BTW get included automatically by the U-Boot build system. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2022-04-12clk: imxrt: Use dts for anatop base addressJesse Taube
In Linux IMX and IMXRT use the device tree to hold the anatop address. The anatop is used in clock drivers as it controls the internal PLLs This will move the macro from asm/arch-imxrt to the device tree. This presumably should also be done with the other IMX boards as well. Signed-off-by: Jesse Taube <Mr.Bossman075@gmail.com>
2021-06-09ARM: dts: imxrt1050: add usbotg1, usbphy1 and usbmisc nodesGiulio Benetti
Usb is now supported so add all required nodes for it in imxrt1050. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2021-06-09ARM: dts: imxrt1050-evk: move all u-boot, dm-spl to ↵Giulio Benetti
imxrt1050-evk-u-boot.dtsi file At the moment a lot of u-boot,dm-spl properties are present in board .dts file but this is not correct since u-boot,dm-spl property is u-boot specific and must be listed into the separate imrt1050-evk-u-boot.dtsi file. So let's move every u-boot,dm-spl property present in imxrt1050-evk.dts to imxrt1050-evk-u-boot.dtsi file. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2021-06-09ARM: dts: imxrt1050: set lcdif clocks according to mxsfb driverGiulio Benetti
Lcdif needs both "pix" and "axi" clocks to be enabled so let's add them to lcdif node. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2021-06-09ARM: dts: imxrt1050: move lcdif assigned clock to dtsiGiulio Benetti
Since we assume pll5 is the default lcdif clock source let's move assigned-clocks(-parents) properties to .dtsi file. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2021-06-09ARM: dts: imxrt1050: add gpt1 nodeGiulio Benetti
Add gpt1 node for using it as timer. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2021-06-09ARM: dts: imxrt1050: add node label to oscGiulio Benetti
Let's add node label to osc to be used as clock source for other nodes. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2020-06-08ARM: dts: imxrt1050: indent lcdif node correctlyGiulio Benetti
Accidentally submitted a patch with indentation not correct, let's fix it by indenting wrong lines. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com> Acked-by: Peng Fan <peng.fan@nxp.com>
2020-04-18ARM: dts: imxrt1050: allow this dtsi file to be compiled in LinuxGiulio Benetti
Linux doesn't provide skeleton.dtsi file so let's remove its include and provide #address-cells/size-cells = <1> that were defined in skeleton.dtsi before. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2020-04-18ARM: dts: i.mxrt1050: add lcdif nodeGiulio Benetti
Add lcdif node to SoC. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2020-01-14ARM: dts: imxrt1050: add dtsi fileGiulio Benetti
Add dtsi file for i.MXRT1050. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
