2023-04-12 | dm: dts: Convert driver model tags to use new schema | Simon Glass | |
Now that Linux has accepted these tags, move the device tree files in U-Boot over to use them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> | |||
2022-10-24 | board: gateworks: venice: add imx8mm-gw7904 support | Tim Harvey | |
The GW7904 is based on the i.MX 8M Mini SoC featuring: - LPDDR4 DRAM - eMMC FLASH - microSD connector with UHS support - LIS2DE12 3-axis accelerometer - Gateworks System Controller - IMX8M FEC - 2x RS232 off-board connectors - PMIC - 10x bi-color LED's - 1x miniPCIe socket with PCIe and USB2.0 - 802.3at Class 4 PoE - 10-30VDC input via barrel-jack Signed-off-by: Tim Harvey <tharvey@gateworks.com> |
