Align the new pinfunc names with header file for all iMX7ULP EVK and ARM2
DTS files.
Also update the EVK DTS files to align with kernel for Rev A3
board. Removed the extcon node for USB ID, since A3 board uses USB ID pin
not GPIO.
Signed-off-by: Ye Li <ye.li@nxp.com>
Default address of earlycon parameter is not correct,
use correct value for imx7ulp_evk.
Test: imx7ulp_evk boots ok.
Change-Id: I2cecb6bfacca573013313ba4ae3783784ccfd506
Signed-off-by: Luo Ji <ji.luo@nxp.com>
Add EVK board support.
Add the evk dts file.
LOG:
U-Boot 2017.03-rc2-00038-gab86c1d (Feb 22 2017 - 15:59:58 +0800)
CPU: Freescale i.MX7ULP rev1.0 at 500 MHz
Reset cause: POR
Boot mode: Dual boot
Model: NXP i.MX7ULP EVK
DRAM: 1 GiB
MMC: FSL_SDHC: 0
In: serial@402D0000
Out: serial@402D0000
Err: serial@402D0000
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 0
Signed-off-by: Peng Fan <peng.fan@nxp.com>
