path: root/arch/arm/dts/imx7-cm.dts
2021-05-02imx: Add support for Ronetix's iMX7-CM boardIlko Iliev
Console boot log: U-Boot SPL 2021.04-00836-ga6232e065d-dirty (Apr 16 2021 - 15:16:35 +0200) Trying to boot from MMC1 U-Boot 2021.04-00836-ga6232e065d-dirty (Apr 16 2021 - 15:16:35 +0200) CPU: Freescale i.MX7D rev1.3 1000 MHz (running at 792 MHz) CPU: Commercial temperature grade (0C to 95C) at 44C Reset cause: POR Model: Ronetix iMX7-CM Board Board: iMX7-CM DRAM: 512 MiB PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11 MMC: FSL_SDHC: 0, FSL_SDHC: 2 Loading Environment from MMC... OK In: serial Out: serial Err: serial Net: Warning: ethernet@30be0000 (eth0) using random MAC address - fe:be:37:01:5a:3f eth0: ethernet@30be0000 Hit any key to stop autoboot: 0 Signed-off-by: Ilko Iliev <iliev@ronetix.at>
