path: root/arch/arm/dts/imx6ull-colibri.dts
2019-11-03ARM: dts: imx6ull-colibri: change hierarchy of DTS filesIgor Opaniuk
Introduce imx6ull-colibri-u-boot.dtsi for u-boot specific properties to keep original imx6ull-colibri.dts in sync with Linux. Move all contents of imx6ull-colibri.dts to imx6ull-colibri.dtsi + additionally fix checkpatch warnings. Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-07-29ARM: dts: colibri-imx6ull: extend lcdif nodeIgor Opaniuk
Provide proper display timings for lcdif node, used by mxsfb DM_VIDEO enabled framebuffer driver. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com> Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-06-11colibri-imx6ull: fix usb host modeMarcel Ziswiler
This fixes an issue with USB host mode. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25ARM: dts: colibri-imx6ull: update device treeMarcel Ziswiler
Fix compatible node to use regular Toradex notation. Annotate device tree with standard Colibri pin muxing comments. Use open-drain I2C pin muxings. Alphabetically re-order iomuxc nodes. Rename snvs-ad7879-int-grp touch interrupt node as per Linux device tree. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25ARM: dts: colibri-imx6ull: add osc32k_32k_out pinctrlMarcel Ziswiler
Add GPIO1_IO03__OSC32K_32K_OUT pin muxing. While at it also fix indentation of pinfunc header file. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25ARM: dts: colibri-imx6ull: fix uart-has-rtscts propertyMarcel Ziswiler
Remove vendor pre-fix fsl, from uart-has-rtscts property. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25colibri-imx6ull: migrate fec to using driver modelMarcel Ziswiler
Migrate Ethernet FEC to using driver model. Drop PHY_MICREL_KSZ90X1 which slipped in from Apalis iMX6. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25colibri-imx6ull: migrate usb to using driver modelMarcel Ziswiler
Migrate USB to using driver model. Add USBH_PEN GPIO regulator. While at it also add alias e.g. as required for UMS. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25colibri-imx6ull: migrate mmc to using driver modelMarcel Ziswiler
Migrate MMC to using driver model. Migrate USDHC to using pinctrl. While at it also add GPIO1_IO03__OSC32K_32K_OUT pin muxing. While at it also update copyright period. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2018-07-23board: toradex: add Colibri iMX6ULL supportStefan Agner
Add support for the Colibri iMX6ULL module which comes with on-board raw NAND. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
