path: root/arch/arm/dts/imx6qdl-tqma6.dtsi
2020-04-17arm: dt: imx6qdl: add tqma6[qdl] som on mba6 mainboardMichael Krummsdorf
The device trees for TQMa6x SOM support variations in - CPU type: imx6dl- or imx6q- - MBa6 I2C bus access: -mba6a (i2c1) or -mba6b (i2c3) (plus the respective common/module include trees) - USBH1 is directly connected to a hub - USBOTG is connected to a separate connector and can act as host/device or full OTG port. Signed-off-by: Michael Krummsdorf <michael.krummsdorf@ew.tq-group.com>
