Synchronise device trees with linux-next next-20220708.
The MaxLinear GPY111 PHY is being used on some boards due to part
availability. Add support for this PHY which requires a longer reset
post-delay and RGMII delay configuration.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Remove board_ehci_hcd_init function that is not used with DM_USB
and replace its functionality with device-tree configuraton that treats
USB HUB RST# as a gpio enable for the usbh1 vbus regulator.
The Gateworks Ventana boards have always had usb0=usbh1 and usb1=usbotg
because OTG is often subloaded on these boards and a bit in the EEPROM
which flagging that OTG is subloaded is used to remove the dt node via the
alias.
U-Boot DM_USB UMS requires the usb0 alias be assigned to the usbotg
so fix the usb0 alias in order for UMS to work.
Fixes 72c46327f03f: ("imx: ventana: enable dm support for USB")
Enable driver model support for FEC ethernet which allows us to remove
the iomux and board_eth_init function. Replace the toggling of the ethernet
phy reset with dt configuration.
Enable driver model support for PCI which allows us to remove the
eth1000_initialize() call. Additionally enable PCI_INIT_R to scan for
PCI devices on init such as the e1000 that is present on the GW552x.
Convert board_pci_fixup to use dm callback and remove pcidisable env
variable which is not supported for DM_PCI and thus leave PCI always
enabled during init.
Enable driver model support for MMC and SATA.
Note that DM_MMC requires aliases for your mmc devices so
they are added to the dts. Linux does not support enumerating mmc
devices by alias so these are not present in the Linux dts.
Note that we still need board_mmc_init() and board_mmc_getcd() for
not DM SPL to support MMC.
Add Gateworks Ventana dts/dtsi files from Linux 5.11 in preparation for
conversion to driver-model.
