path: root/arch/arm/dts/imx6q-cm-fx6.dts
2017-12-29ARM: imx: cm-fx6: reinstate USB support by syncing the devicetree with LinuxChristopher Spinrath
Commit 5248930ebf48 ("dm: imx: cm_fx6: Enable more driver model support") enabled driver model support for USB, thereby effectively removing USB support because the cm_fx6 devicetree in the U-Boot does *not* enable the USB nodes. Reinstate the USB support by syncing the devicetree with Linux whose devicetree enables the USB nodes properly. More precisely, use the devicetree found in Linux v4.15-rc1 with the following two changes: 1) Remove the audio mux; the required dt-bindings header is not present in the U-Boot. 2) Keep the usdhc3 MMC controller node currently present in the U-Boot's devicetree to retain the ability to boot from MMC. Fixes: 5248930ebf48 ("dm: imx: cm_fx6: Enable more driver model support") Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-17dm: imx: cm_fx6: Add device tree for cm_fx6Simon Glass
Add this file so we can use device-tree control for cm_fx6. It comes from linux 4.12. Signed-off-by: Simon Glass <sjg@chromium.org>
