2020-12-06 | arm: dts: aristainetos: sync with changes in linux | Heiko Schocher | |
sync with comaptible changes in linux from Krzysztof Kozlowski. https://patchwork.kernel.org/project/linux-arm-kernel/patch/20200930190143.27032-12-krzk@kernel.org/ Signed-off-by: Heiko Schocher <hs@denx.de> | |||
2020-12-06 | imx6: remove not longer supported aristainetos boards | Heiko Schocher | |
Removed aristainetos2, 2b, 2b-csl. This boards have been recalled and destroyed. Adapt board code to remove stuff not needed anymore. Fix checkpatch warning, remove fdt_high and initrd_high from default environment. Signed-off-by: Heiko Schocher <hs@denx.de> zu remove | |||
2020-01-07 | imx6: aristainetos: add support for rev C board | Heiko Schocher | |
add support for revision C boards. This board has no longer a NAND. Signed-off-by: Heiko Schocher <hs@denx.de> |
