path: root/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-23ARM: dts: Freescale: re-license device tree files under GPLv2+/X11Pankaj Bansal
The current GPL only licensing on the device trees makes it very impractical for other software components licensed under another license. To make it easier to reuse them, re-license the the device trees for Freescale (now NXP) SoCs and boards under GPLv2+/X11 dual license. Same trend is followed in linux. Cc: Priyanka Jain <priyanka.jain@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: York Sun <york.sun@nxp.com> Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls2080ardb: Add QSPI-boot supportPriyanka Jain
QSPI-boot is supported on LS2088ARDB RevF board with LS2088A SoC. LS2088ARDB RevF Board has limitation that QIXIS can not be accessed. CONFIG_FSL_QIXIS is not enabled. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
