Now that Linux has accepted these tags, move the device tree files in
U-Boot over to use them.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
As part of the effort of making U-Boot work with the same device tree as
Linux, there is an issue with the "xfi" phy-mode. To be precise, in
Linux there was a discussion (for those who have time to read:
https://lore.kernel.org/netdev/1576768881-24971-2-git-send-email-madalin.bucur@oss.nxp.com/)
which led to a patch:
https://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next.git/commit/?id=c114574ebfdf42f826776f717c8056a00fa94881
TL;DR: "xfi" was standardized in Linux as "10gbase-r".
This patch changes the relevant occurrences in U-Boot to use "10gbase-r"
instead of "xfi" wherever applicable.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
According to new qspi driver, some properties like "bus-num, num-cs,
big-endian" are no longer used. Device endiannes can be determined from
device-type data in driver.
Now use board specific compatibles, generic node names and specific
labels to align with linux device-tree properties.
Also consolidate spi-max-frequency to 50Mhz treewide.
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
In order to maintain compatibility with the Linux DTS, the entire fsl-mc
node is added but instead of being probed by a dedicated bus driver it
will be a simple-mfd.
Also, annotate the external MDIO nodes and describe the PHYs (4 x AQR405
and 4 x CS4340). Also, add phy-handles for the dpmacs to their
associated PHY.
Signed-off-by: Ioana Ciornei <ioana.ciornei@nxp.com>
Add some slave nodes to support the i2c dm on the device side under the i2c0.
Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot
dts files. This compatible has been added in sf_probe, let use it.
This patch switches to jedec,spi-nor when spi-flash is used in the DTS
and DTSI files, and removed spi-flash when jedec,spi-nor is already
present.
The x86 dts are switched in a separate commit since it depends on a change
in fdtdec.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
TFABOOT support includes:
- ls2088ardb_tfa_defconfig to be loaded by trusted firmware
- environment address and size changes for TFABOOT
- define BOOTCOMMAND for TFABOOT
- remove EL3 specific erratas for TFABOOT
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have multiple licenses (in
these cases, dual license) declared in the SPDX-License-Identifier tag.
In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A
or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B"
as per the Linux Kernel style document. Note that parenthesis are
allowed so when they were used before we continue to use them.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
The current GPL only licensing on the device trees makes it very
impractical for other software components licensed under another
license.
To make it easier to reuse them, re-license the the device trees for
Freescale (now NXP) SoCs and boards under GPLv2+/X11 dual license.
Same trend is followed in linux.
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Mingkai Hu <mingkai.hu@nxp.com>
Cc: York Sun <york.sun@nxp.com>
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
QSPI-boot is supported on LS2088ARDB RevF board with LS2088A SoC.
LS2088ARDB RevF Board has limitation that QIXIS can not be accessed.
CONFIG_FSL_QIXIS is not enabled.
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com>
