path: root/arch/arm/dts/fsl-ls1046a-qds.dtsi
2020-05-19treewide: Update fsl qspi node dt properties as per spi-mem driverKuldeep Singh
According to new qspi driver, some properties like "bus-num, num-cs, big-endian" are no longer used. Device endiannes can be determined from device-type data in driver. Now use board specific compatibles, generic node names and specific labels to align with linux device-tree properties. Also consolidate spi-max-frequency to 50Mhz treewide. Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-03-30dm: arm64: ls1046a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1046A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-12-06armv8: dts: fsl-ls1046a: add sata node supportPeng Ma
One ls1046a, there is one SATA 3.0 advanced host controller interface which is a high-performance SATA solution that delivers comprehensive and fully-compliant generation 3 (1.5 Gb/s - 6.0 Gb/s) serial ATA capabilities, in accordance with the serial ATA revision 3.0 of Serial ATA International Organization. Add sata node to support this feature. Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-23ARM: dts: Freescale: re-license device tree files under GPLv2+/X11Pankaj Bansal
The current GPL only licensing on the device trees makes it very impractical for other software components licensed under another license. To make it easier to reuse them, re-license the the device trees for Freescale (now NXP) SoCs and boards under GPLv2+/X11 dual license. Same trend is followed in linux. Cc: Priyanka Jain <priyanka.jain@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: York Sun <york.sun@nxp.com> Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-11-21armv8: ls1046aqds: add lpuart supportShaohui Xie
LPUART0 is used by default, and it's using platform clock. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14armv8: ls1046aqds: Add LS1046AQDS board supportShaohui Xie
LS1046AQDS Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * Two XFI 10G ports * Two SGMII ports * Two RGMII ports PCIe: supports Gen 1 and Gen 2 SATA 3.0: one SATA 3.0 port USB 3.0: two micro AB connector and one type A connector UART: supports two UARTs up to 115200 bps for console Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
