path: root/arch/arm/dts/fsl-ls1028a.dtsi
2019-06-19arm: ls1028a: define the integrated PCI bus (ECAM)Alex Marginean
LS1028A includes an integrated PCI bus with 11 PCI functions residing on bus 0. ECAM plus the device register space takes up 256MB of address space. Signed-off-by: Alex Marginean <alexm.osslist@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-19armv8: ls1028a: Add ecc address node for sata.Peng Ma
Move the ecc addr from driver to dts Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22arm: dts: fsl-ls1028a: add sp805 watchdog nodeQiang Zhao
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22armv8: ls1028a: Add NXP LS1028A SoC supportYuantian Tang
Ls1028a SoC is based on Layerscape Chassis Generation 3.2 architecture with features: 2 ARM v8 Cortex-A72 cores, CCI400, SEC, DDR3L/4, LCD, GPU, TSN ENETC, 2 USB 3.0, 2 eSDHC, 2 FlexCAN, 2 SPI, SATA, 8 I2C controllers, 6 LPUARTs, GPIO, SAI, qDMA, eDMA, GIC, TMU etc. Signed-off-by: Sudhanshu Gupta <sudhanshu.gupta@nxp.com> Signed-off-by: Rai Harninder <harninder.rai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Signed-off-by: Tang Yuantian <andy.tang@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
