path: root/arch/arm/dts/fsl-ls1028a-qds-x7xx-sch-30842.dtsi
2021-11-09arm: dts: ls1028a: update the labelsMichael Walle
Update the labels of the nodes to match the kernel ones. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Vladimir Oltean <vladimir.oltean@nxp.com> Tested-by: Vladimir Oltean <vladimir.oltean@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2021-11-09arm: dts: ls1028a: move I2C controller nodes into /socMichael Walle
While inserting them into the new location, keep them sorted by the register base offset just like in the linux kernel device tree. Signed-off-by: Michael Walle <michael@walle.cc> Reviewed-by: Vladimir Oltean <vladimir.oltean@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2021-09-28net: freescale: replace usage of phy-mode = "sgmii-2500" with "2500base-x"Vladimir Oltean
After the discussion here: https://lore.kernel.org/netdev/20210603143453.if7hgifupx5k433b@pali/ which resulted in this patch: https://patchwork.kernel.org/project/netdevbpf/patch/20210704134325.24842-1-pali@kernel.org/ and many other discussions before it, notably: https://patchwork.kernel.org/project/linux-arm-kernel/patch/1512016235-15909-1-git-send-email-Bhaskar.Upadhaya@nxp.com/ it became apparent that nobody really knows what "SGMII 2500" is. Certainly, Freescale/NXP hardware engineers name this protocol "SGMII 2500" in the reference manuals, but the PCS devices do not support any "SGMII" specific features when operating at the speed of 2500 Mbps, no in-band autoneg and no speed change via symbol replication . So that leaves a fixed speed of 2500 Mbps using a coding of 8b/10b with a SERDES lane frequency of 3.125 GHz. In fact, "SGMII 2500 without in-band autoneg and at a fixed speed" is indistinguishable from "2500base-x without in-band autoneg", which is precisely what these NXP devices support. So it just appears that "SGMII 2500" is an unclear name with no clear definition that stuck. As such, in the Linux kernel, the drivers which use this SERDES protocol use the 2500base-x phy-mode. This patch converts U-Boot to use 2500base-x too, or at least, as much as it can. Note that I would have really liked to delete PHY_INTERFACE_MODE_SGMII_2500 completely, but the mvpp2 driver seems to even distinguish between SGMII 2500 and 2500base-X. Namely, it enables in-band autoneg for one but not the other, and forces flow control for one but not the other. This goes back to the idea that maybe 2500base-X is a fiber protocol and SGMII-2500 is an MII protocol (connects a MAC to a PHY such as Aquantia), but the two are practically indistinguishable through everything except use case. NXP devices can support both use cases through an identical configuration, for example RX flow control can be unconditionally enabled in order to support rate adaptation performed by an Aquantia PHY. At least I can find no indication in online documents published by Cisco which would point towards "SGMII-2500" being an actual standard with an actual definition, so I cannot say "yes, NXP devices support it". Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com> Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
2021-09-28net: update NXP copyright textVladimir Oltean
NXP Legal insists that the following are not fine: - Saying "NXP Semiconductors" instead of "NXP", since the company's registered name is "NXP" - Putting a "(c)" sign in the copyright string - Putting a comma in the copyright string The only accepted copyright string format is "Copyright <year-range> NXP". This patch changes the copyright headers in the networking files that were sent by me, or derived from code sent by me. Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com> Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
2021-07-06arm: dts: ls1028a: enable the switch CPU port for the LS1028A-QDSVladimir Oltean
Due to an upstream change, the ls1028a.dtsi bindings for the mscc_felix switch got accepted with all ports disabled by default and with no link to the DSA master - this needs to be done on a per board basis. Note that enetc-2 is not currently disabled in the ls1028a.dtsi, but presumably at some point it might become. Explicitly enable it in the QDS device trees anyway, to proactively avoid issues when that happens. Fixes: a7fdac7e2a2a ("arm: dts: ls1028a: define QDS networking protocol combinations") Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com> Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
2021-04-15arm: dts: ls1028a: define QDS networking protocol combinationsAlex Marginean
Includes DT definition for the following serdes protocols using various PHY cards: 85xx, 13xx, 65xx, 9999, 7777. Note that the default device tree for QDS now uses 85xx. Enabling any of the others requires patching the fsl-ls1028a-qds.dtsi file (the includes at the bottom of the file). The phy-handle is specified as a path rather than a label because it is possible to use the #include multiple times (meaning that more than one PHY riser card of one type is inserted), and therefore, there would be duplicate labels with the same name. LBRW means that the board needs lane B rework before using this dtsi. Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com> Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
