path: root/arch/arm/dts/exynos54xx.dtsi
2018-12-13dm: exynos: sound: Convert to use driver modelSimon Glass
Update snow's device tree and config to use driver model for sound. Also update the others as best we can. Spring does not appear to have audio support in the kernel. The smdk5250 and smdk5420 boards use a wolfson codec which I cannot test with. So the only boards that is tested and known to work are snow, pit and pi. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-25exynos: dts: Add display-related device tree fragmentsSimon Glass
Bring in device tree pieces related to display from Linux 4.4 for: - snow - peach_pit - peach_pi - spring Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2016-05-25exynos: dts: Add pwm device tree nodeSimon Glass
Add this node from Linux v4.4 so that PWMs can be used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-02Exynos54xx: dts: add ADC nodePrzemyslaw Marczak
This commit adds common ADC node, which is disabled as default. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-05exynos: dts: Sync up I2C ports with the kernelSimon Glass
The kernel uses upper case for I2C unit addresses. Follow the same convention to reduce differences. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-04-06dts: exynos54xx: Add samsung, pwm-out-gpio property to FIMD nodeAjay Kumar
Now that the exynos_fb driver supports handling backlight GPIO via DT, specify pwm output property via FIMD DT node. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-22dm: exynos: dts: Adjust device tree files for U-BootSimon Glass
The pinctrl bindings used by Linux are an incomplete description of the hardware. It is possible in most cases to determine the register address of each, but not in all cases. By adding an additional property we can fix this, and avoid adding a table to U-Boot for every single Exynos SOC. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: Bring in pinctrl dts files from Linux kernelSimon Glass
Bring in required device tree files for pinctrl from Linux v3.14. These are initially unchanged and have a number of pieces not needed by U-Boot. Note that exynos5420 is renamed to exynos54xx here since we want to support exynos5422 also. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: dts: Convert /include/ to #includeSimon Glass
We should be consistent about this. The kernel has moved to #include which breaks error reporting to some extent but does allow us to include binding files. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-05video: exynos_fimd: Add framework to disable FIMD sysmmuAjay Kumar
On Exynos5420 and newer versions, the FIMD sysmmus are in "on state" by default. We have to disable them in order to make FIMD DMA work. This patch adds the required framework to exynos_fimd driver, and disables FIMD sysmmu on Exynos5420. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-06-23Exynos5420: Introduce support for the Peach-Pit boardAkshay Saraswat
While the Exynos5420 chip is used in both Smdk5420 and in the Peach-Pit line of devices, there could be other boards using the same chip, so a common configuration file is being added (exynos5420.h) as well as two common device tree files (exynos54xx.dtsi & exynos5420.dtsi). The peach board as declared in boards.cfg is a copy of smdk5420 declaration. The configuration files are similar, but define different default device trees, console serial ports and prompts. The device tree files for smdk5420 and peach-pit inherit from the same common file. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
