path: root/arch/arm/dts/exynos5420-peach-pit.dts
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-12-13dm: exynos: sound: Convert to use driver modelSimon Glass
Update snow's device tree and config to use driver model for sound. Also update the others as best we can. Spring does not appear to have audio support in the kernel. The smdk5250 and smdk5420 boards use a wolfson codec which I cannot test with. So the only boards that is tested and known to work are snow, pit and pi. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-13dm: sound: exynos: Correct codec bus addressesSimon Glass
For snow the codec is at address 0x11 on the i2c bus, in 7-bit format. The device tree and code are in 8-bit format (i.e. shifted left one bit). Fix both. Fix pit in a similar way. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-25exynos: dts: Add display-related device tree fragmentsSimon Glass
Bring in device tree pieces related to display from Linux 4.4 for: - snow - peach_pit - peach_pi - spring Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-31exynos: x86: dts: Add tpm nodes to the device tree for Chrome OS devicesSimon Glass
Add a TPM node to the various Chromebooks so that driver can be converted to driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-05dts: exynos: pit: Add a new node for the parade video bridge driverSimon Glass
The new driver supports driver model and configuration via device tree. Add a node for pit, which needs this driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: dts: Support EC tunnel and main TPS65090 regulatorSimon Glass
On pit and pi the TPS65090 regulator is connected only to the EC and we must use a tunnel to get to it. The existing U-Boot support relies on a special driver. Add a tunnel definition so that the new device-model TPS65090 driver can be used unmodified. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: dts: Sync up I2C ports with the kernelSimon Glass
The kernel uses upper case for I2C unit addresses. Follow the same convention to reduce differences. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-05-14tpm: Rename Infineon TPM to slb9645ttSimon Glass
This name is used in Linux, so use it in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18cros_ec: exynos: Match up device tree with kernel versionSimon Glass
The U-Boot device trees are slightly different in a few places. Adjust them to remove most of the differences. Note that U-Boot does not support the concept of interrupts as distinct from GPIOs, so this difference remains. For sandbox, use the same keyboard file as for ARM boards and drop the host emulation bus which seems redundant. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-06dts: peach_pit: Add SLP and RST GPIO properties in parade DT nodeAjay Kumar
Now that parade driver supports reading SLP and RST GPIO from DT, specify the same in parade DT node. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-01-29dm: exynos: dts: Use GPIO bank phandles for GPIOsSimon Glass
U-Boot now supports using GPIOs using bank phandles instead of global numbers. Update the exynos device tree files to use this. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2015-01-05cros-ec-keyboard: Synchronize DT binding from linuxSjoerd Simons
The ChromeOS EC keyboard is used by various different chromebooks. Peach pi being the third board in the u-boot tree to use it (snow and peach pit the other two). Rather then embedding the same big DT node in the peach-pi DT again, copy the dtsi snippit & bindings documentation from linux and include it in all 3 boards. This slightly changes the dt bindings in u-boot: * google,key-rows becomes keypad,num-rows * google,key-colums becomes keypad,num-colums * google,repeat-delay-ms and google,repeat-rate-ms are no longer used and replaced by hardcoded values (similar to tegra kbc) Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: Convert SPI to driver modelSimon Glass
Move the exynos SPI driver over to driver model. This removes quite a bit of boilerplate from the driver, although it adds some for driver model. A few device tree additions are needed to make the SPI flash available. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-22dm: exynos: dts: Convert /include/ to #includeSimon Glass
We should be consistent about this. The kernel has moved to #include which breaks error reporting to some extent but does allow us to include binding files. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-08exynos: dts: Add device tree node for cros_ec keyboardSimon Glass
Add a keyboard definition so that the keyboard can be used on pit. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08Exynos: Use 900MHz ARM frequency in SPL for peach_pitSimon Glass
The device seems to hang in SPL if the full speed is used when booting from USB, perhaps because the PMIC has not been set to the maximum ARM core voltage yet. Slow it down to a reliable speed. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-05ARM: exynos: peach_pit: Add DT nodes for fimd and parade bridge chipAjay Kumar
This patch adds DT properties for fimd and the parade bridge chip present on peach_pit. The panel supports 1366x768 resolution. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-06-23Exynos5420: Introduce support for the Peach-Pit boardAkshay Saraswat
While the Exynos5420 chip is used in both Smdk5420 and in the Peach-Pit line of devices, there could be other boards using the same chip, so a common configuration file is being added (exynos5420.h) as well as two common device tree files (exynos54xx.dtsi & exynos5420.dtsi). The peach board as declared in boards.cfg is a copy of smdk5420 declaration. The configuration files are similar, but define different default device trees, console serial ports and prompts. The device tree files for smdk5420 and peach-pit inherit from the same common file. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
