path: root/arch/arm/dts/exynos5250.dtsi
2018-12-13dm: exynos: sound: Convert to use driver modelSimon Glass
Update snow's device tree and config to use driver model for sound. Also update the others as best we can. Spring does not appear to have audio support in the kernel. The smdk5250 and smdk5420 boards use a wolfson codec which I cannot test with. So the only boards that is tested and known to work are snow, pit and pi. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-25exynos: dts: Add pwm device tree nodeSimon Glass
Add this node from Linux v4.4 so that PWMs can be used in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-05exynos: dts: Sync up I2C ports with the kernelSimon Glass
The kernel uses upper case for I2C unit addresses. Follow the same convention to reduce differences. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-10-22dm: exynos: dts: Adjust device tree files for U-BootSimon Glass
The pinctrl bindings used by Linux are an incomplete description of the hardware. It is possible in most cases to determine the register address of each, but not in all cases. By adding an additional property we can fix this, and avoid adding a table to U-Boot for every single Exynos SOC. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: Bring in pinctrl dts files from Linux kernelSimon Glass
Bring in required device tree files for pinctrl from Linux v3.14. These are initially unchanged and have a number of pieces not needed by U-Boot. Note that exynos5420 is renamed to exynos54xx here since we want to support exynos5422 also. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: dts: Convert /include/ to #includeSimon Glass
We should be consistent about this. The kernel has moved to #include which breaks error reporting to some extent but does allow us to include binding files. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-30DTS: Add dts support for SMDK5420Rajeshwari Birje
This patch adds dts support for SMDK5420. exynos5.dtsi created is a common file which has the nodes common to both 5420 and 5250. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-10-20exynos5: dts: Add device node for XHCIVivek Gautam
Adding device node for xhci host controller to enable usb 3.0 on exynos5250. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-24DTS: Addition of I2S0 channel and replacing I2S1Dani Krishna Mohan
This patch enables default I2S0 channel.And I2S platform parameter has been moved to a common file viz exynos5.dtsi. Signed-off-by: Dani Krishna Mohan <krishna.md@samsung.com>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-06-26cros: exynos: add cros-ec device nodes to exynos5250-snow.dtsHung-ying Tyan
This patch adds cros-ec related device nodes to exynos5250-snow.dts. It also adds a gpio node to exynos5250.dtsi. Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-24EXYNOS5: FDT: Add serial device node valuesRajeshwari Shinde
This patch adds the device node required for serial driver Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-13EXYNOS5: FDT: Add DWMMC device node dataAmar
This patch adds DWMMC device node data for exynos5. This patch also adds binding file for DWMMC device node. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Signed-off-by: Amar <amarendra.xt@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27EXYNOS5: Add device node for DPAjay Kumar
Add DT node and bindings documentaion for DP. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27EXYNOS5: Add device node for FIMDAjay Kumar
Add DT node and bindings documentation for FIMD. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-12Exynos5: FDT: Add TMU device node valuesAkshay Saraswat
Fdt entry for Exynos TMU driver specific pre-defined values used for calibration of current temperature and defining threshold values. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: Add device node for USB.Rajeshwari Shinde
This patch adds the device node required for USB Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: FDT: Add SPI device node dataRajeshwari Shinde
Add SPI device node data for exynos. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: FDT: Add sound device node dataRajeshwari Shinde
Add sound device node data for exynos Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: FDT: Add I2C device node dataRajeshwari Shinde
Add I2C device node data for exynos Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-26EXYNOS5: FDT: add initial dts file for EXYNOS5250, SMDK5250Hatim RV
This patch adds initial dts file for EXYNOS5250 SoC. This dts file currently include only ethernet devices and properties. More devices to be added in subsequent patches. Also add the dts file for SMDK5250 board which uses the EXYNOS5250 dts file. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
