path: root/arch/arm/dts/exynos5250-spring.dts
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-02-09spring: Update flashmap detailsSimon Glass
Update the flashmap so that this board can be started over USB A-A. It is slightly different from snow. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-02-09spring: Update sound to use max98088 codecSimon Glass
Update the spring settings to use this codec, which is what it actually shipped with. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-12-13dm: exynos: sound: Convert to use driver modelSimon Glass
Update snow's device tree and config to use driver model for sound. Also update the others as best we can. Spring does not appear to have audio support in the kernel. The smdk5250 and smdk5420 boards use a wolfson codec which I cannot test with. So the only boards that is tested and known to work are snow, pit and pi. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-08-06arm: spring: fix alias of mmc correctlyMinkyu Kang
2016-05-25exynos: dts: Add display-related device tree fragmentsSimon Glass
Bring in device tree pieces related to display from Linux 4.4 for: - snow - peach_pit - peach_pi - spring Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-31exynos: x86: dts: Add tpm nodes to the device tree for Chrome OS devicesSimon Glass
Add a TPM node to the various Chromebooks so that driver can be converted to driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-05exynos: Add support for springSimon Glass
Spring is the first ARM-based HP Chromebook 11. It is similar to snow and it uses the same Samsung Exynos5250 chip. But has some unusual features. Mainline support for it has lagged snow (both in kernel and U-Boot). Now that the exynos5 code is common we can support spring just by adding a device tree and a few lines of configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
