path: root/arch/arm/dts/exynos4210.dtsi
2017-12-05arm: dts: exynos4: fix the device-tree compile warningJaehoon Chung
After updating dtc-1.4.5 version, there are too many warning. This patch is to fix about exynos4 series. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-22dm: exynos: dts: Adjust device tree files for U-BootSimon Glass
The pinctrl bindings used by Linux are an incomplete description of the hardware. It is possible in most cases to determine the register address of each, but not in all cases. By adding an additional property we can fix this, and avoid adding a table to U-Boot for every single Exynos SOC. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: Bring in pinctrl dts files from Linux kernelSimon Glass
Bring in required device tree files for pinctrl from Linux v3.14. These are initially unchanged and have a number of pieces not needed by U-Boot. Note that exynos5420 is renamed to exynos54xx here since we want to support exynos5422 also. Signed-off-by: Simon Glass <sjg@chromium.org>
