path: root/arch/arm/dts/ethernut5.dts
2017-09-13ARM: dts: ethernut5: Fix the build warningWenyou Yang
Fix the building warning as below: ---8<---- Warning (reg_format): "reg" property in /i2c-gpio-0/pcf8563@50 has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) Warning (avoid_default_addr_size): Relying on default #address-cells value for /i2c-gpio-0/pcf8563@50 Warning (avoid_default_addr_size): Relying on default #size-cells value for /i2c-gpio-0/pcf8563@50 --->8---- Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-04board: ethernut5: Update to support DT and DMWenyou.Yang@microchip.com
Add the dts files to support deivce tree, update the configuration files to support the device tree and driver model. The peripheral clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
