path: root/arch/arm/dts/dragonboard410c-uboot.dtsi
2019-01-18dts: db410: fix indentationRamon Fried
Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-07-19dts: db410c: added smem nodesRamon Fried
Added necessary nodes for Qualcomm smem driver. Signed-off-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-19configs: dragonboard410c: remove env partition offsetRamon Fried
BOOT2 is not partitioned, no need for partition offset. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-06-18db410c: fix alignment of dts fileRamon Fried
Alignment was wrong, missing one tab. fix it. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-06-04db410c: Added pre-relocation attribute to pinctrlRamon Fried
u-boot,dm-pre-reloc was missing from pinctrl and it's children node. causing failure to configure pin mux before relocation. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-05-08db410c: set clk node to be probed before relocationRamon Fried
The clock node is used by the serial driver and it's needed before relocation. This patch ensures that the msm-serial driver can actually use the clock node. Signed-off-by: Ramon Fried <ramon.fried@linaro.org>
2017-11-17configs: dragonboard410c: Save environment data on eMMCJorge Ramirez-Ortiz
Save the environment data at the end of the boot partition on emmc Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2016-04-01board: Add Qualcomm Dragonboard 410C supportMateusz Kulikowski
This commit add support for 96Boards Dragonboard410C. It is board based on APQ8016 Qualcomm SoC, complying with 96boards specification. Features (present out of the box): - 4x Cortex A53 (ARMv8) - 2x USB Host port - 1x USB Device port - 4x LEDs - 1x HDMI connector - 1x uSD connector - 3x buttons (Power, Vol+, Vol-/Reset) - WIFI, Bluetooth with integrated antenna - 8GiB eMMC U-Boot boots chained with fastboot in 64-bit mode. For detailed build instructions see readme.txt in board directory. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Tested-by: Simon Glass <sjg@chromium.org>
