path: root/arch/arm/dts/dm816x.dtsi
2018-12-07arm: dts: am33xx: Sync dts with Linux 4.20.0Felix Brack
This patch synchronizes the am33xx SoC specific files with those from Linux 4.20.0. Hence all board maintainers of am33xx based boards are on the cc list. The main purpose of this patch is to prevent further diverging of the dts files from U-Boot and those from Linux. It aims to set the stage for the synchronization of board specific dts files. Example: I'm the maintainer of the PDU001 board: once this patch is applied successfully I will make changes to the board specific dts file in Linux only and then post a patch with a copy of this exact dts file to U-Boot. This will make U-Boot and Linux remain in sync. The stumbling block of https://patchwork.ozlabs.org/patch/943627 was removed by the patch https://patchwork.ozlabs.org/patch/962428 from Lokesh Vutla (many thanks!). This omap-serial driver allows using the Linux am33xx.dtsi file in U-Boot. Other changes to dts and dtsi files made by this patch are mainly to prevent _new_ warnings during the build process. Especially the warning at pinmux@800 stating 'unnecessary #address-cells/#size-cells without "ranges" or child "reg"' was not removed. This warning is a good example showing the benefit of the synchronization: if it needs to be fixed it will be fixed in Linux and ported back to U-Boot. Buildman reports all 46 am33xx SoC based boards to build fine, with warnings of course. Nevertheless this patch should be tested thoroughly on as many boards as possible to prevent any collateral damage. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-05ti816x: Import dts files from Linux Kernel v4.11Tom Rini
This brings in the required dts/dtsi files for the TI8168-EVM from the Linux Kernel v4.11 release. Signed-off-by: Tom Rini <trini@konsulko.com>
