path: root/arch/arm/dts/da850-evm-u-boot.dtsi
2020-07-09arm: dts: include gpio nodes for card detectWalter Lozano
Several MMC drivers use GPIO for card detection with cd-gpios property in the MMC node pointing to a GPIO node. However, as U-Boot tries to save space by keeping only required nodes using u-boot* properties, several devices tree result in having only in the MMC node but not the GPIO node associated to cd-gpios. This patch, fixes several ocurrence of this issue. Signed-off-by: Walter Lozano <walter.lozano@collabora.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
2020-03-03arm: dts: am335x: add 'u-boot, dm-pre-reloc' to panelDario Binacchi
Add the "u-boot,dm-pre-reloc" property to the "ti,tilcdc,panel" compatible node. In this way the video-uclass module can allocate the amount of memory needed to be assigned to the frame buffer. For boards that support Linux the property is added to the *-u-boot.dtsi file since it is a u-boot specific dt flag. Ran building tests with CONFIG_AM335X_LCD enabled and disabled for the following configurations: - brxre1_defconfig --> success - am335x_guardian_defconfig --> success - am335x_evm_defconfig --> success - da850evm_defconfig --> failure with CONFIG_AM335X_LCD enabled Enabling CONFIG_AM335X_LCD in da850evm_defconfig causes building errors even without applying the patch. The driver has never been enabled on the da850 and must be adapted for this platform. Signed-off-by: Dario Binacchi <dariobin@libero.it> Tested-by: Dario Binacchi <dariobin@libero.it> Reviewed-by: Felix Brack <fb@ltec.ch>
2019-07-31ARM: dts: da850-evm: Fix MDIO pinmuxAdam Ford
In attempts to speed up SPL and reduce size, the MDIO pin muxing was inadvertently affected. Since the ethernet driver will setup the pin muxing when ethernet is loaded, this patch will also pinmux the MDIO pins at the same time. Once an DM compatible MDIO driver is available, this can be removed. Fixes: 877ab2423bc2 ("ARM: davinci: da850: Manual pinmux only when PINCTRL not available") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-07-29davinci: da850-evm: enable driver model for NANDBartosz Golaszewski
Enable the driver-model on da850-evm. We need to add a dummy nand node to the device tree, as the real nand node is a sub-node of the aemif device. On linux the aemif driver populates all its child nodes, but we can't do it in u-boot currently. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
2019-04-14Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
Conflicts: arch/arm/dts/armada-385-amc.dts arch/arm/dts/armada-xp-theadorable.dts arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-12ARM: davinci: da850evm: Enable SPL_OF_CONTROL without PLATDATAAdam Ford
With the memory mapping giving us some more avialable RAM, this updates the da850-evm-u-boot.dtsi to include the serial port, SPI and Flash nodes along with some dependent nodes in the SPL dtb. This also removes the platform data initialization code for the serial port and SPI Flash. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-09-11ARM: dts: da850-evm-u-boot: Remove redundant entriesAdam Ford
With the re-sync from Linux 4.18, several entries in da850-evm-u-boot.dtsi are no longer necessary, so this patch removes them. Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-29ARM: da850-evm: Enable DM_I2CAdam Ford
With DM now enabled with the device tree pulled from Linux, we can enable DM_I2C in U-Boot. Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add DM_I2C_COMPAT to da850_am18xxevm to fix warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-29arm: dts: da850: Migrate da850-evm DTS files from Linux 4.13-RC5Adam Ford
A few small additional items are needed to support DM_SPI and DM_SERIAL, so those were added to da850-evm-u-boot.dtsi Signed-off-by: Adam Ford <aford173@gmail.com>
