Synchronize R-Car device trees with Linux 6.1.7,
commit 21e996306a6afaae88295858de0ffb8955173a15 .
The following script has been used for the synchronization:
$ for i in $(cd arch/arm/dts/ ; ls -1 r8a* | grep -v 'u-boot.dts' ; sed -n '/#include/ s@.*"\(.*\)"@\1@p' $(ls -1 r8a* | grep -v 'u-boot.dts')) ; do
if [ -e /linux-2.6/arch/arm64/boot/dts/renesas/$i ] ; then
cp /linux-2.6/arch/arm64/boot/dts/renesas/$i arch/arm/dts/ ;
elif [ -e /linux-2.6/arch/arm/boot/dts/$i ] ; then
cp /linux-2.6/arch/arm/boot/dts/$i arch/arm/dts/
else
echo "NOT FOUND: $i"
fi
done
$ git add $( ( cd arch/arm/dts/ ; ls -1 r8a* | grep -v 'u-boot.dts' ; sed -n '/#include/ s@.*"\(.*\)"@\1@p' $(ls -1 r8a* | grep -v 'u-boot.dts')) | tr " " "\n" | sed 's@^@arch/arm/dts/@g' )
Move the include/dt-bindings/{clk,clock}/versaclock.h header used by
the renesas boards to match Linux 6.1.y as well.
Keep arch/arm/dts/r8a774c0-u-boot.dtsi sdhi3 node as it is now used
by the arch/arm/dts/r8a774c0-cat874.dts board.
Pick s@spi-flash@flash@ change in arch/arm/dts/r8a779a0-falcon-u-boot.dts
from "ARM: dts: Synchronize R-Car V3U DTs with Linux 5.18.3" .
Adjust R8A77990 Ebisu CONFIG_SYS_MMC_ENV_DEV from 2 to 0 to reflect
the card enumeration in ebisu.dtsi /aliases DT node .
Adjust R8A7795 and R8A7796 ULCB CONFIG_SYS_MMC_ENV_DEV from 1 to 0 to
reflect the card enumeration in ulcb.dtsi /aliases DT node .
Signed-off-by: Marek Vasut <marek.vasut+renesas@mailbox.org>
Signed-off-by: Tam Nguyen <tam.nguyen.xa@renesas.com> # r8a779a0-falcon-u-boot.dts
Signed-off-by: Hai Pham <hai.pham.ud@renesas.com> # r8a779a0-falcon-u-boot.dts
The device trees for the Beacon RZ/G2[MNH] boards have undergone
some changes over time, so resync them now.
There is a QSPI NOR flash part on the board. Because this chip isn't
yet supported in Linux, but it is supported in U-Boot, and the
face that the RPC_SPI compatible names are different in U-Boot and
Linux, the device tree updates are confined to -u-boot.dtsi files.
In order to use the QSPI, TF-A must leave RPC unlocked by compiling
TF-A with RZG_RPC_HYPERFLASH_LOCKED=0.
Reviewed-by: Biju Bas <biju.das.jz@bp.renesas.com>
Update the RZ/G2M dtsi and r8a774a1-beacon-rzg2m-kit kit
from Renesas repo destined to become 5.12-rc1.
The Beacon EmbeddedWorks kit is based on the R8A774A1 SoC also
known as the RZ/G2M.
The kit consists of a SOM + Baseboard and supports microSD,
eMMC, Ethernet, a couple celular radios, two CAN interfaces,
Bluetooth and WiFi.
