path: root/arch/arm/dts/bcm96878.dts
2022-10-31arm: bcmbca: add bcm6878 SoC supportWilliam Zhang
BCM6878 is an ARM A7 based PON Broadband SoC. It is part of the BCA (Broadband Carrier Access origin) chipset family so it's added under ARCH_BCMBCA platform. This initial support includes a bare-bone implementation and dts with CPU subsystem, memory and ARM PL011 uart. This SoC is supported in the linux-next git repository so the dts and dtsi files are copied from linux with minor fix-up that needs to be upstreamed to linux as well. The u-boot image can be loaded from flash or network to the entry point address in the memory and boot from there. Signed-off-by: William Zhang <william.zhang@broadcom.com>
