path: root/arch/arm/dts/bcm2836.dtsi
2019-06-12fdt: update bcm283x device tree sources to Linux 5.1-rc6 stateHeinrich Schuchardt
Updating the bcm283x device tree sources adds the device trees for - Raspberry Pi 3 Model A+ - Raspberry Pi 3 Model B+ - Raspberry Pi Compute Module IO board rev1 - Raspberry Pi Compute Module 3 IO board V3.0 - Raspberry Pi Zero Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Matthias Brugger <mbrugger@suse.com>
2017-10-16fdt: update bcm283x device tree sources to Linux 4.14 stateAlexander Graf
Upstream Linux has received a few device tree updates to the RPi which we should propagate into the builtin U-Boot one as well to gain hardware support. This patch bumps the dts files to their 4.14 Linux counterparts with the exception of sdhost on 32bit RPi versions. There we stay with iproc as the sdhost driver is missing in U-Boot. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-11-28fdt: import bcm283x device tree sources from the linux kernel treeFabian Vogt
This patch adds device trees for the bcm283x platform to be used with OF_CONTROL. The version 4.8-rc7 of the linux kernel was used as source. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Fabian Vogt <fvogt@suse.com> Reviewed-by: Simon Glass <sjg@chromium.org>
