Now that Linux has accepted these tags, move the device tree files in
U-Boot over to use them.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
This commit fixes various devicetree warnings in the at91 devicetrees
like:
arch/arm/dts/sama5d36ek_cmp.dtb: Warning (avoid_unnecessary_addr_size): /gpio_keys: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
These warnings make buildman report failed builds for most of at91 boards.
Thus, fixing it.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
To support driver model and device tree, use the SPI-flash-based
AT45xxx DataFlash driver, DataFlash is a kind of SPI flash.
Instead of ATMEL_DATAFLASH_SPI DataFlash older driver that will
be removed in the future.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
The device tree source files of at91sam9rlek boards are copied from
the Linux v4.10, do the changes as below.
- Add the reg property for the pinctrl node.
- Move the gpio (pioA, pioB, pioC, pioD) nodes as the pinctrl's
slibling nodes, instead of the child nodes.
- Add the "u-boot,dm-pre-reloc" property for the dbgu node are used
in board_init_f stage.
- Fix the compilation warnings.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
