path: root/arch/arm/dts/at91sam9g45-corvus.dts
2017-06-23atmel, at91: fix corvus boardHeiko Schocher
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support" corvus board comes not up anymore. Fix it. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-06-26corvus DTS / DM supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [rebase on current ToT, don't delete gurnard DTB creation] Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
