path: root/arch/arm/dts/at91sam9g20.dtsi
2017-05-09ARM: dts: at91: Add dts files for at91sam9260ek/9g20ekWenyou Yang
The device tree source files of at91sam9g20ek and at91sam9260ek boards are copied from the Linux v4.10, do the changes below. - Fix the build error for the usb0 node. - Add the reg property for the pinctrl node. - Move the gpio (pioA, pioB, pioC ...) nodes as the pinctrl's slibling nodes, instead of the child nodes. - Add the "u-boot,dm-pre-reloc" property for the dbgu node are used in board_init_f stage. - Add the clk pinctrl of the mmc0 node. - Fix the compilation warnings. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-26arm: at91: dts: Bring in dts files for AT91SAM9G20 and SAM9260Heiko Schocher
Add this files from Linux v4.6-rc5 66b8a424d: [workqueue: fix ghost PENDING flag while doing MQ IO] Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Andreas Bießmann <andreas@biessmann.org>
