path: root/arch/arm/dts/at91sam9263ek.dts
2017-08-04board: at91sam9263ek: Use SPI-flash-based AT45xxx DataFlashWenyou.Yang@microchip.com
To support driver model and device tree, use the SPI-flash-based AT45xxx DataFlash driver, DataFlash is a kind of SPI flash. Instead of ATMEL_DATAFLASH_SPI DataFlash older driver that will be removed in the future. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09ARM: dts: at91: Add dts files for at91sam9263ekWenyou Yang
The device tree source files of at91sam9263ek boards are copied from the Linux v4.10, do the changes as below. - Add the reg property for the pinctrl node. - Move the gpio (pioA, pioB, pioC, pioD, pioE) nodes as the pinctrl's slibling nodes, instead of the child nodes. - Add the "u-boot,dm-pre-reloc" property for the dbgu node are used in board_init_f stage. - Fix the compilation warnings. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
