Now that Linux has accepted these tags, move the device tree files in
U-Boot over to use them.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
w+arch/arm/dts/.at91sam9260ek.dtb.pre.tmp:119.21-123.7: Warning (spi_bus_reg): /ahb/apb/spi@fffc8000/mtd_dataflash@0: SPI bus unit address format error, expected "1"
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
To support driver model and device tree, use the SPI-flash-based
AT45xxx DataFlash driver, DataFlash is a kind of SPI flash.
Instead of ATMEL_DATAFLASH_SPI DataFlash older driver that will
be removed in the future.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
The device tree source files of at91sam9g20ek and at91sam9260ek
boards are copied from the Linux v4.10, do the changes below.
- Fix the build error for the usb0 node.
- Add the reg property for the pinctrl node.
- Move the gpio (pioA, pioB, pioC ...) nodes as the pinctrl's
slibling nodes, instead of the child nodes.
- Add the "u-boot,dm-pre-reloc" property for the dbgu node are used
in board_init_f stage.
- Add the clk pinctrl of the mmc0 node.
- Fix the compilation warnings.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
