The GPIO polarity for onewire must be GPIO_ACTIVE_HIGH.
On previous versions this used to work as it looks like the right flag values
are being passed since :
https://lists.denx.de/pipermail/u-boot/2020-April/407195.html
And that series broke the old functionality for onewire nodes.
Some boards had the correct value for the polarity, but it wasn't clear
so I replaced it with the right macro for the flag, instead of an empty value.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot
dts files. This compatible has been added in sf_probe, let use it.
This patch switches to jedec,spi-nor when spi-flash is used in the DTS
and DTSI files, and removed spi-flash when jedec,spi-nor is already
present.
The x86 dts are switched in a separate commit since it depends on a change
in fdtdec.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Add onewire node in device tree for TM series LCDs
Convert the board to support the video driver model, add the device
tree node, and remove the unnecessary code.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
Add the code to set the ethernet mac address from eeprom by using
the common code from the common folder.
Add the device tree files for sama5d4 Xplained board.
The dts files are copied from Linux-4.4, do the following changes.
- add reg property for pinctrl node.
- move the gpio nodes(pioA, pioB, pioC ...) from the pinctrl child's
nodes to its slibling nodes.
- add the "u-boot,dm-pre-reloc" property to determine which nodes
which are needed by SPL and by the board_init_f stage.
- fix the compilation warnings.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
