path: root/arch/arm/dts/armada-xp-theadorable.dts
2019-04-14Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
Conflicts: arch/arm/dts/armada-385-amc.dts arch/arm/dts/armada-xp-theadorable.dts arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-04-12arm: sync armada-xp dts files from Linux 5.0Chris Packham
Bring in the Armada 370/XP dts/dtsi files from Linux. As U-Boot hasn't got the new NAND driver the updating binding has not been included. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-02-05arm: mvebu: theadorable: Enable video / LCD support with the new DM driverStefan Roese
With the new DM_VIDEO support in the Armada XP LCD driver, this patch adds the needed DT node for the LCD controller to the theadorable dts file. This DT property is not added to the Armada XP dtsi files, as this LCD feature is pretty unusual for this SoC and I personally know of no other board that uses this controller. This patch also enables CONFIG_BMP_16BPP/24BPP/32BPP, as the "old" bmp command supported these BMP files. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2019-02-05arm: mvebu: armada-xp-theadorable.dts: Enable PCIe DT nodesStefan Roese
Now that the PCIe driver supports DM and DT parsing, enable the PCIe DT nodes that are used by this board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Phil Sutter <phil@nwl.cc> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: VlaoMao <vlaomao@gmail.com>
2018-11-06arm: mvebu: armada-xp-theadorable.dts: Change CS# for 2nd FPGAStefan Roese
The new board version has the 2nd FPGA connected via CS# 0 instead of 2 on SPI bus 1. Change this setup in the DT accordingly. Please note that this change does still work on the old board version because the CS signal is not used on this board. Signed-off-by: Stefan Roese <sr@denx.de>
2018-11-06arm: mvebu: armada-xp-theadorable.dts: Add "spi-flash" compatible propertyStefan Roese
Add the "spi-flash" compatible string so that the generic sf_probe driver can probe the SPI flash on the theadorable Armada-XP board. Signed-off-by: Stefan Roese <sr@denx.de>
2016-03-24arm: mvebu: theadorable: Add StratixV FPGA programming supportStefan Roese
This patch adds support for Altera StratixV bitstream programming. 2 FPGAs are connected to the SPI busses. This patch uses board specific write code to program the bitstream via SPI direct write mode. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-27arm: mvebu: Add support for the Armada XP theadorable boardStefan Roese
This patch adds support for the Armada XP (MV78260) based theadorable board. Its equipped with onboard DDR3, UART, ethernet, I2C, SPI NOR, LCD and SATA (SSD) interfaces / devices. Two defconfigs are added: theadorable_defconfig: The production U-Boot version with a stripped down drivers and feature list. This removes networking, USB and PCI support. theadorable_debug_defconfig: The debugging / testing U-Boot version with full support for all drivers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
