path: root/arch/arm/dts/armada-8040-db.dts
2018-05-29dts: mvebu: a80x0: Enable SD/eMMC interfacesKonstantin Porotchkin
Enable SDHCI interface on AP and CP0 in A80x0 DTS files Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Evan Wang <xswang@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-05-09phy: marvell: Replace PHY_TYPE_KR with PHY_TYPE_SFIStefan Roese
Use correct naming as done in the latest Marvell U-Boot version as well. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Igal Liberman <igall@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-05-09mvebu: dts: a80x0: Sync the DB DTS with standard config AKonstantin Porotchkin
Sync the default configuration of Armada-8040-DB with Marvell u-boot-2015 standard configuration "A" for the same board. The standard configuration "A" enables 2 PCIe slots on CP0 and 3 PCIe slots on CP1. This is the main configuration used for u-boot and Linux tests. This patch also re-arranges the DTS file entries by grouping all nodes related to CP0 and CP1. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-03-29arm64: marvell: dts: add PPv2.2 description to Armada 7K/8KThomas Petazzoni
This commit adds the description of the PPv2.2 hardware block for the Marvell Armada 7K and Armada 8K processors, and their corresponding Armada 7040 and 8040 Development boards. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-12-12arm64: mvebu: Add pin control nodes to A8K family DTS filesKonstantin Porotchkin
Add pin control nodes to APN806, CP-master, CP-slave and Armada-7040 and Armada-8040 boards DTS files Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-12-12arm64: mvebu: Modify the A8K SPI and I2C config in DTSKonstantin Porotchkin
Align the Armada-8040-db and Armada-7040-db SPI and I2C DTS settings with latest DB settings: - 8040-db: disable i2c0 and spi0 on AP (MPPs are reserved for SDIO) - 8040-db: disable cps_i2c0 on CP1 - 8040-db: enable spi1 on CP1 (the new location of the boot flash) The spi1 on CP1 is aliased as spi0 since this is the way the driver enumerates it. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-12-05arm64: mvebu: armada-8040-db.dts: Add I2C and SPI aliasesStefan Roese
Add I2C and SPI aliases to enable usage in U-Boot. Otherwise U-Boot will not be able to use the SPI NOR chip for environment storage and use "i2c dev 0" to select this I2C bus. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-12-05arm64: mvebu: armada-8040-db.dts: Add COMPHY configurationStefan Roese
This patch adds the COMPHY device tree configuration to the DT file for the Marvell DB-88F8040 devel board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2016-12-05arm64: mvebu: Add Armada-80x0 dts/dtsi filesStefan Roese
Add the latest version of the DT files from the Linux kernel. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
