path: root/arch/arm/dts/armada-8040-clearfog-gt-8k.dts
2018-11-20ARM: mvebu: dts: add Clearfog GT-8KRabeeh Khoury
The SolidRun Clearfog GT-8K is based on Armada 8040. https://wiki.solid-run.com/doku.php?id=products:a8040:clearfoggt8k The config file is identical to the Macchiatobin one (mvebu_mcbin-88f8040_defconfig) with only the default device-tree changed. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
