path: root/arch/arm/dts/armada-388-gp.dts
2020-08-13arm: mvebu: armada-388-gp.dts: Fix dtc warningsStefan Roese
Fix these dtc warnings: Warning (reg_format) Warning (avoid_default_addr_size) Signed-off-by: Stefan Roese <sr@denx.de> Cc: Chris Packham <judge.packham@gmail.com> Reviewed-by: Chris Packham <judge.packham@gmail.com>
2019-03-19ARM: mvebu: use correct name for pcie controllerChris Packham
When armada-385.dtsi was sync'd from Linux the name of the node describing the pcie controller was changed from pcie-controller to pcie. Some of the boards that include armada-385.dtsi were missed in the update retaining the old name. This updates the affected boards. Reported-by: Влад Мао <vlaomao@gmail.com> Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-14arm: mvebu: armada-388-gp.dts: Add ethernet aliasesStefan Roese
Adding these aliases enables the update of the MAC addresses from within U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add SPI driver model supportStefan Roese
This patch enables the DM support for the SPI driver and the SPI NOR flash chips. Some MVEBU boards boot from SPI NOR, so adding the aliases and enabling CONFIG_DM_SEQ_ALIAS is needed here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: Add DM and OF_CONTROL support to SPLStefan Roese
This patch adds full DM support to the SPL on MVEBU. Currently only serial is supported. Other drivers will follow. This patch also adds the necessary config values for the DEBUG UART to the MVEBU defconfig files. This came in handy while implementing this DM support. Additionally, the mvebu specific SPL linker script is removed and this common one is used instead: arch/arm/cpu/u-boot-spl.lds This common linker script already handles all special cases. No need to reinvent the wheel for MVEBU here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2015-10-21arm: mvebu: Add basic Armada XP / 38x dtsi/dts filesStefan Roese
These will be needed by the upcoming DM (driver model) support for the Armada XP / 38x SoC's. This will provide DT based probing. The dts files are copied 1:1 from the Linux kernel release v4.2. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
