With commit 8678776df6f5 (arm: mvebu: armada-3720-uDPU: fix PHY mode
definition to sgmii-2500) the PHY mode was switch to "sgmii-2500", even
when this is functionally incorrect since "2500base-x" was not supported
in U-Boot at that time. As this mode is now supported (at least present
in the headers), this patch moves back to the orinal version.
Cc: Jakov Petrina <jakov.petrina@sartura.hr>
Cc: Vladimir Vid <vladimir.vid@sartura.hr>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Currently, all comphy definitions are PHY_TYPE_XX and PHY_SPEEED_XX.
Those definition might be confused with MDIO PHY definitions.
This patch does the following changes:
- PHY_TYPE_XX --> COMPHY_TYPE_XX
- PHY_SPEED_XX --> COMPHY_SPEED_XX
This improves readability, no functional change.
Change-Id: I2bd1d9289ebbc5c16fa80f9870f797ea1bcaf5fa
Signed-off-by: Igal Liberman <igall@marvell.com>
Signed-off-by: Konstantin Porotchkin <kostap@marvell.com>
Commit f49ac7e1c4 switched the default PHY speed to 3.125Gbit to resolve
issues with SFP modules. However, U-Boot does not have a "2500base-x"
phy-mode.
Resolve this by using "sgmii-2500" instead.
Signed-off-by: Jakov Petrina <jakov.petrina@sartura.hr>
Signed-off-by: Vladimir Vid <vladimir.vid@sartura.hr>
Cc: Stefan Roese <sr@denx.de>
This resolves issues with certain SFP modules.
This adds initial support for micro-DPU (uDPU) board which is based on Armada-3720 SoC.
micro-DPU is the single-port FTTdp "distribution point unit" made by Methode Electronics
which offers complete modularity with replaceable SFP modules both for uplink and downlink
(G.hn over twisted-pair, G.hn over coax, 1G and 2.5G Ethernet over Cat-5e cable).
On-board features:
- 512 MiB DDR3
- 2 x 2.5G SFP via HSGMII SERDES interface to the A3720 SoC
- USB 2.0 Type-C connector
- 4GB eMMC
- ETSI TS 101548 reverse powering via twisted pair (RJ45) or coax (F Type)
Cc: Luis Torres <luis.torres@methode.com>
Cc: Scott Roberts <scott.roberts@telus.com>
Cc: Paul Arola <paul.arola@telus.com>
