path: root/arch/arm/dts/am57xx-beagle-x15-revc.dts
2023-04-14arm: dts: am57x: Update devicetree header comments to sync with v6.3-rc6Andrew Davis
Signed-off-by: Andrew Davis <afd@ti.com>
2019-07-26ARM: dts: am57xx: Disable voltage switching for SD cardFaiz Abbas
If UHS speed modes are enabled, a compatible SD card switches down to 1.8V during enumeration. If after this a software reboot/crash takes place and on-chip ROM tries to enumerate the SD card, the difference in IO voltages (host @ 3.3V and card @ 1.8V) may end up damaging the card. The fix for this is to have support for power cycling the card in hardware (with a PORz/soft-reset line causing a power cycle of the card). Because the beaglebone X15 (rev A,B and C), am57xx-evms and am57xx-idks don't have this capability, disable voltage switching for these boards. The major effect of this is that the maximum supported speed mode is now high speed(50 MHz) down from SDR104(200 MHz). Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2017-09-11arm: dts: dra7: sync DT with latest LinuxLokesh Vutla
Sync all dra7* specific dts files with the upstream kernel including changes queued for 4.14 https://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap.git/log/?h=omap-for-v4.14/dt-v3 Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
