path: root/arch/arm/dts/am437x-idk-evm-u-boot.dtsi
2018-12-14dts: Add a u-boot specific dtsi file for the am4372Jean-Jacques Hiblot
This file is used to override the values found in am4372.dtsi Use it to fix the "compatible" options for the controllers used to support the USB (parent bus and syscons). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-06ARM: dts: Add new "generic" am4372 device tree file.Vignesh R
With U-boot runtime board detect for DTB selection a "default" dtb needs to be created. This will be used temporarily until the "proper" dtb is selected. Also, add -u-boot.dtsi for AM437x SK and IDK to enable I2C for board detection via DM_I2C. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
