path: root/arch/arm/dts/am437x-cm-t43.dts
2019-09-13arm: am437x: cm-t43: Add device tree, enable OF_CONTROLSuniel Mahesh
Add device tree from Linux for driver model conversion and enable OF_CONTROL. This will remove the following compile warning: ================================================== Device Tree Source is not correctly specified. Please define 'CONFIG_DEFAULT_DEVICE_TREE' or build with 'DEVICE_TREE=<device_tree>' argument =================================================== Target was compile tested, build was clean. Signed-off-by: Suniel Mahesh <sunil.m@techveda.org>
