path: root/arch/arm/dts/am33xx-u-boot.dtsi
2021-01-12arm: dts: am335x: enable scm_clocks auto bindingDario Binacchi
Adding the 'simple-bus' compatible string to the scm_clocks node will allow its automatic binding. Signed-off-by: Dario Binacchi <dariobin@libero.it>
2021-01-12arm: dts: am335x: enable prcm_clocks auto bindingDario Binacchi
Adding the 'simple-bus' compatible string to the prcm_clocks node will allow its automatic binding. Signed-off-by: Dario Binacchi <dariobin@libero.it>
2019-02-06arm: dts: am33xx: introduce 'am33xx-u-boot.dtsi'Hannes Schmelzer
commit fdce9d35dc36 ("arm: dts: am33xx: Sync dts with Linux 4.20.0") did remove the "u-boot,dm-spl" flag from the 'ocp' bus which was introduced with commit 19aa4ac09db9 ("dts: am33xx: add u-boot, dm-spl to ocp bus") Due to this all boards having CONFIG_SPL_OF_CONTROL enabled are broken because they cannot bind/probe the boot-media interface during SPL stage. This commit introduces the 'am33xx-u-boot.dtsi' which is included with the auto include mechanism. The am33xx-u-boot-dtsi adds the important "u-boot,dm-pre-reloc" to the 'ocp bus' (the root bus of almost all peripherals, at least the bootable ones). The peripherials (mmc, spi, ...) needed during SPL stage need to be equipped with the 'u-boot,dm-pre-reloc' in their responsible dts file. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
