path: root/arch/arm/dts/am335x-brppt1-spi.dts
2021-01-12video: omap: add panel driverDario Binacchi
The previous version of am335x-fb.c contained the functionalities of two drivers that this patch has split. It was a video type driver that used the same registration compatible string that now registers a panel type driver. The proof of this is that two compatible strings were referred to within the same driver. There are now two drivers, each with its own compatible string, functions and API. Furthermore, the panel driver, in addition to decoding the display timings, is now also able to manage the backlight. Signed-off-by: Dario Binacchi <dariobin@libero.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-03-03arm: dts: am335x: add 'u-boot, dm-pre-reloc' to panelDario Binacchi
Add the "u-boot,dm-pre-reloc" property to the "ti,tilcdc,panel" compatible node. In this way the video-uclass module can allocate the amount of memory needed to be assigned to the frame buffer. For boards that support Linux the property is added to the *-u-boot.dtsi file since it is a u-boot specific dt flag. Ran building tests with CONFIG_AM335X_LCD enabled and disabled for the following configurations: - brxre1_defconfig --> success - am335x_guardian_defconfig --> success - am335x_evm_defconfig --> success - da850evm_defconfig --> failure with CONFIG_AM335X_LCD enabled Enabling CONFIG_AM335X_LCD in da850evm_defconfig causes building errors even without applying the patch. The driver has never been enabled on the da850 and must be adapted for this platform. Signed-off-by: Dario Binacchi <dariobin@libero.it> Tested-by: Dario Binacchi <dariobin@libero.it> Reviewed-by: Felix Brack <fb@ltec.ch>
2019-04-12dts: switch spi-flash to jedec, spi-nor compatibleNeil Armstrong
There is no reason not to use the Linux "jedec,spi-nor" binding in U-Boot dts files. This compatible has been added in sf_probe, let use it. This patch switches to jedec,spi-nor when spi-flash is used in the DTS and DTSI files, and removed spi-flash when jedec,spi-nor is already present. The x86 dts are switched in a separate commit since it depends on a change in fdtdec. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Evgeniy Paltsev <paltsev@synopsys.com> Reviewed-by: Rick Chen <rick@andestech.com> Reviewed-by: Patrick Delaunay <Patrick.delaunay@st.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-07-19board/BuR/brppt1: convert brppt1 boards to driver modelHannes Schmelzer
- add a devicetree for each variant (mmc, spi, nand) - drop unneeded code from board and bur/common - drop unneeded stuff from config header files - minor adaptions to be compliant with driver model (requesting gpio,..) - harmonize the commandset over all brppt1 targets Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
