path: root/arch/arm/dts/am335x-bone-common.dtsi
2016-05-27ARM: dts: am335x: fix cd-gpios definition as per hardware design and dt ↵Mugunthan V N
binding docs As per mmc device tree binding documentation card detect gpio has to be active low signal. When a hardware is designed with active high card detect, gpio polarity has to be changed with cd-inverted dt property. In AM335x the card detect gpio is designed as active low gpio. So correcting the dt card detect gpio definition. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2016-05-27ARM: dts: am335x-bone: Enable uart and timerLokesh Vutla
Allow am335x-bone.dts to be built and enable uart and timer for all beaglebones. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-12am33xx: Update DT files, add am335x_gp_evm_config targetTom Rini
- Re-sync DT files for am33xx with Linux Kernel v4.1 - Include DT file now for the "AM335x GP EVM" and build target for it, via device tree and DM. - We only need to provide platform data for UART when OF_CONTROL isn't also enabled really. We can just push GPIO to coming from DT Signed-off-by: Tom Rini <trini@konsulko.com>
2014-10-23dm: dts: omap: Select correct console for beagleboneSimon Glass
Select serial0 as the console. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-06-11am33xx/omap: Enable CONFIG_OF_CONTROLSimon Glass
Add support for device tree control and add device tree files for the beaglebone black initially. Signed-off-by: Simon Glass <sjg@chromium.org>
