path: root/arch/arm/dts/am335x-baltos.dts
2019-11-03arm: dts: am335x: sync cpsw/mdio/phy with latest linux - drop phy_idGrygorii Strashko
Synchronize CPSW/MDIO/PHY DT nodes with latest linux - replace deprecated phy_id property with phy-handle. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Cc: Heiko Schocher <hs@denx.de> Cc: Felix Brack <fb@ltec.ch> Cc: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-12-03arm: baltos: move the board to CONFIG_BLKYegor Yefremov
Use DM for both MMC and USB subsystems and use dedicated DTS for U-Boot configuration. Disable SPL support for GPIO and remove EVMSK leftover for DDR power control via GPIO. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
