The global timer used to divide the waiting cycles by two for no
reason, which lead to too short delays (e.g. when waiting for PHY).
This fixes an issue seen when bootdelay is 0 and the boot command
requires network:
FEC Waiting for PHY auto negotiation to complete......... TIMEOUT !
Support L2 cache which is available on for the Cortex-A5 core on
some Vybrid SoCs (VFx1x series). Vybrid seems to use revision r3p2
of the PL310 cache controller. To enable the cache controller use
this two configuration symbols:
#define CONFIG_SYS_L2_PL310
#define CONFIG_SYS_PL310_BASE CA5_L2C_BASE_ADDR
Note: U-Boot is currently not able to detect the existence of the
L2 cache at runtime. Hence enabling these configurations leads to
a crash on SoCs which do not have a L2 cache (e.g. VF500 on
Colibri VF50)
To create the soc environment variable we concatenate two strings
on the stack. So far, strcat has been used for the first string as
well as for the second string. Since the variable on the stack is
not initialized, the first strcat may not start using the first
entry in the character array. This then could lead to an buffer
overflow on the stack.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add support for ARM global timer. This allows to save the platform
wide PIT timer for other purposes such as MQX on the secondary
Cortex-M4 core.
Rename the serial loader boot mode to "serial". Also add an alias
for the ESDHC1 controller, which provides the standard MMC connection
for the Colibri SO-DIMM default pinout.
Implement boot mode for Vybrid SoC. Boot mode selection works much
like the i.MX6 implementation. Provide a standard set of boot modes
for the two eSDHC instances and use the reserved mode to jump into
SoC's recovery mechanism, the serial downloader.
Enables caches which provides a rather huge speedup of the boot loader.
Also mark the on-chip RAM as cachable since this is the area U-Boot runs
from.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Vybrid product family consists of several rather similar SoC which
can be determined by softare during boot time. This allows use of
variable ${soc} for Linux device tree files. Detect VF5xx CPU's by
reading the CPU count register. We can determine the second number
of the CPU type (VF6x0) which indicates the presence of a L2 cache.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Patch e11c6c27 (arm: Allow lr to be saved by board code) introduced
a different method to return from save_boot_params(). The SPL support
for AXP has been pulled and changing to this new method is now
required for SPL to work correctly.
Cc: Luka Perkov <luka.perkov@sartura.hr>
Work_92105 from Work Microwave is an LPC3250-
based board with the following features:
- 64MB or 128MB SDR DRAM
- 1 GB SLC NAND, managed through MLC controller.
- Ethernet
- Ethernet + PHY SMSC8710
- I2C:
- EEPROM (24M01-compatible)
- RTC (DS1374-compatible)
- Temperature sensor (DS620)
- DACs (2 x MAX518)
- SPI (through SSP interface)
- Port expander MAX6957
- LCD display (HD44780-compatible), controlled
through the port expander and DACs
This board has SPL support, and uses the LPC32XX boot
image format.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
This driver only supports Driver Model, not legacy model.
The controller's Reed-Solomon ECC hardware is
used except of course for raw reads and writes.
It covers in- and out-of-band data together.
The SPL framework is supported.
Add support for Inverse Path USB armory board, an open source
flash-drive sized computer based on Freescale i.MX53 SoC.
http://inversepath.com/usbarmory
Signed-off-by: Andrej Rosano <andrej@inversepath.com>
Cc: Chris Kuethe <chris.kuethe@gmail.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Vagrant Cascadian <vagrant@debian.org>
Tested-By: Vagrant Cascadian <vagrant@debian.org>
Tested-by: Chris Kuethe <chris.kuethe@gmail.com>
Move the MX5 based boards to arch/arm/cpu/armv7/mx5, following the
commit: 89ebc82137bebb11a8191f8b9cbf08f2533ae8bc
Back in fc46bae a "clean up" was introduced that intended to reconcile
some of the AM335x codepaths based on how AM43xx operates.
Unfortunately this introduced a regression on the DDR2 platforms. This
was un-noticed on DDR3 (everything except for Beaglebone White) as we
had already populated sdram_config correctly in sequence. This change
brings us back to the older behavior and is fine on all platforms.
Tested on Beaglebone White, Beaglebone Black and AM335x GP EVM
Reported-by: Matt Ranostay <mranostay@gmail.com>
The existing setting for rpll_sdiv generates 70.5Mhz RPLL
video clock to drive 1366x768 panel on peach_pit.
This clock rate is not sufficient to drive 1920x1080 panel on peach-pi.
So, we adjust rpll_sdiv to 3 so that it generates 141Mhz pixel clock
which can drive peach-pi LCD.
This change doesn't break peach-pit LCD since 141/2=70.5Mhz, i.e FIMD
divider at IP level will get set to 1(the required divider setting
will be calculated and set by exynos_fimd_set_clock()) and hence
peach-pit LCD still works fine.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Add get_lcd_clk and set_lcd_clk callbacks for Exynos5800 needed by
exynos video driver.
Commit 2e82e9252695a612ab0cbf40fa0c7368515f6506 'Exynos: Clock: Cleanup
soc_get_periph_rate' introduced a bug in I2C config. This patch makes cros_ec
keyboard working again on Samsung Chromebook (snow).
Changes in V2: reorder lines as requested by Joonyoung Shim.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Akshay Saraswat <akshay.s@samsung.com>
Cc: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Simon Glass <sjg@chroimum.org>
Tested-by: Simon Glass <sjg@chroimum.org>
board/armltd/vexpress64/vexpress64.c
Patches that added the Tegra210 pinctrl driver and renamed directories
arch/arm/cpu/tegra{$soc}-common -> arch/arm/mach-tegra/tegra-${soc}
crossed. Move the Tegra210 pinctrl driver to the correct location. This
wasn't detected since Tegra210 support is in the process of being added,
and isn't buildable yet.
Signed-off-by: Tom Warren <twarren@nvidia.com>
make the CPU clock selectable via Kconfig
this removes the sunxi specific CONFIG_CLK_FULL_SPEED defined in each
soc header and replaces it's use in board/sunxi/board.c with
CONFIG_SYS_CLK_FREQ from Kconfig which allows us to configure board
specific frequency on boot
Signed-off-by: Iain Paton <ipaton0@gmail.com>
[hdegoede@redhat.com s/CONFIG_SYS_CLK_FREQ/CONFIG_TIMER_CLK_FREQ/ for the
arch-timer clk speed on sun7i to fix mis-compile on sun7i]
Acked-by: Hans de Goede <hdegoede@redhat.com>
clock_set_pll1 would pick the next highest available cpu clock speed if
a value not in the pre defined table was selected. this potentially
results in overclocking the soc.
reverse the selection method so that we select the next lowest speed
and add the missing 912Mhz setting that's requested by sun7i which also
uses the sun4i clock code.
The usb0 / otg phy on sunxi boards has a bug where it wrongly detects a
high speed squelch on usb reset deassert when a lo speed device is plugged in.
The android kernel has a work around for this in the form of temporary
disabling the phy's squelch detection on reset deassert, this commit adds
the same workaround to the u-boot sunxi musb code, thereby fixing various usb
lo speed devices not working.
Tested with a (before non working) usb keyboard and a usb 2.4 GHz wireless
keyboard/mouse combo receiver.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
BCM2835 (used on Raspberry Pi) and BCM2836 (used on Raspberry Pi 2)
are similar enough. One of the biggest differences is the ARM
processor. It is reasonable to collect the source files into a
single place, arch/arm/mach-bcm283x/.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
This option has a bool type, not hex.
Fix it and enable it if CONFIG_DM is on because Driver Model always
requires malloc memory. Devices are scanned twice, before/after
relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc
memory before relocation. As it is board-independent, handle it
globally.
Acked-by: Robert Baldyga <r.baldyga@samsung.com>
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig
as 0x400. Each defconfig or Kconfig need not repeat the same value.
My main motivations for this commit are:
[1] Follow the arch/arm/Makefile style of Linux Kernel
[2] Maintain compiler options systematically
Currently, we give -march=* and -mtune=* options inconsistently:
Only some of the CPUs pass -march=* and -mtune=* options.
By collecting such options into the single place arch/arm/Makefile
we can tell which options are missing at a glance.
[3] Prepare for deprecating arch/*/cpu/*/config.mk
Note:
This commit just moves the compiler options so as not to change
the behavior at all. It does not care about the correctness of
the given options. Fox example, "-march=armv5te" might be better
than "-march=armv4" for ARM946EJS, but it is beyond the scope this
commit. Also, filling the missing -march=* and -tune=* is left
to follow-up patches.
Various files are needlessly rebuilt every time due to the version and
build time changing. As version.h is not actually needed, remove the
include.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Macpaul Lin <macpaul@andestech.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Philippe Reynes <tremyfr@yahoo.fr>
Cc: Eric Jarrige <eric.jarrige@armadeus.org>
Cc: "David Müller" <d.mueller@elsoft.ch>
Cc: Phil Edworthy <phil.edworthy@renesas.com>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: Torsten Koschorrek <koschorrek@synertronixx.de>
Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
Add basic SECO MX6Q/uQ7 board support (Ethernet, UART, SD are supported).
It also adds a Kconfig skeleton to later add more SECO board (supporting
SoC and board variants).
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Freescale boards are currently all defined in arch/arm/Kconfig, which
makes them hard to detect.
Moreover the MX6 SoC variant (Q, D, DL, S, SL) selection is currently
done via the SYS_EXTRA_OPTIONS option which marked as deprecated.
Move to a more standard way to select sub-architecture and board by
creating a Kconfig under arch/arm/cpu/armv7/mx6 and a new ARCH_MX6
option.
Existing MX6 board definitions should be moved in this new Kconfig in
choice menu, and new boards should be directly declared in this menu.
RX51 has a secure logic which uses different parameters compared to
traditional implementation. So, make the generic secure acr write
over-ride-able by board file and refactor rx51 code to use this.
While at it, enable the OMAP3 specific errata code for 454179, 430973,
621766.
Signed-off-by: Nishanth Menon <nm@ti.com>
Enable the OMAP3 specific errata code for 454179, 430973, 621766
and while at it, remove legacy non-revision checked errata logic.
Tested-by: Matt Porter <mporter@konsulko.com>
Update to existing recommendation for L2ACTLR configuration to prevent
system instability and optimize performance.
These apply to both OMAP5 and DRA7.
Reported-by: Vivek Chengalvala <vchengalvala@ti.com>
This patch enables the workaround for ARM errata 798870 for OMAP5 /
DRA7 which says "If back-to-back speculative cache line fills (fill
A and fill B) are issued from the L1 data cache of a CPU to the
L2 cache, the second request (fill B) is then cancelled, and the
second request would have detected a hazard against a recent write or
eviction (write B) to the same cache line as fill B then the L2 logic
might deadlock."
An l2auxctlr accessor implementation for OMAP5 and DRA7 is introduced
here as well.
Signed-off-by: Praveen Rao <prao@ti.com>
Signed-off-by: Angela Stegmaier <angelabaker@ti.com>
omap_smc1 is now generic enough to remove duplicate
omap3_gp_romcode_call logic that omap3 introduced.
As part of this change, move to using the generic lowlevel_init.S for
omap3 as well.
set_pl310_ctrl_reg does use the Secure Monitor Call (SMC) to setup
PL310 control register, however, that is something that is generic
enough to be used for OMAP5 generation of processors as well. The only
difference being the service being invoked for the function.
So, convert the service to a macro and use a generic name (same as
that used in Linux for some consistency). While at that, also add a
data barrier which is necessary as per recommendation.
While at this, smc #0 is maintained as handcoded assembly thanks to
various gcc version eccentricities, discussion thread:
http://marc.info/?t=142542166800001&r=1&w=2
621766: Under a specific set of conditions, executing a sequence of
NEON or vfp load instructions can cause processor deadlock
Impacts: Every Cortex-A8 processors with revision lower than r2p1
Work around: Set L1NEON to 1
Based on ARM errata Document revision 20.0 (13 Nov 2010)
430973: Stale prediction on replaced inter working branch causes
Cortex-A8 to execute in the wrong ARM/Thumb state
Work around: Set IBE to 1
454179: Stale prediction may inhibit target address misprediction on
next predicted taken branch
Work around: Set IBE and disable branch size mispredict to 1
Also provide a hook for SoC specific handling to take place if needed.
Add workaround for Cortex-A15 ARM erratum 798870 which says
"If back-to-back speculative cache line fills (fill A and fill B) are
issued from the L1 data cache of a CPU to the L2 cache, the second
request (fill B) is then cancelled, and the second request would have
detected a hazard against a recent write or eviction (write B) to the
same cache line as fill B then the L2 logic might deadlock."
Implementations for SoC families such as Exynos, OMAP5/DRA7 etc
will be widely different.
Every SoC has slightly different manner of setting up access to L2ACLR
and similar registers since the Secure Monitor handling of Secure
Monitor Call(smc) is diverse. Hence an weak function is introduced
which may be overriden to implement SoC specific accessor implementation.
Based on ARM errata Document revision 18.0 (22 Nov 2013)
Disable the warm reset and enable the cold reset for a more reliable
restart ('reset'). This is taken from the Linux kernel, see imx_src_init()
in arch/arm/mach-imx/src.c.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
There is no need to include asm/bootm.h twice, so remove one.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
