Implement module type (e.g. VF50 vs. VF61) auto detection based on L2
cache availability. Set specific ARM core clock (e.g. 400 vs. 500 MHz)
as well as Linux machine id number.
While at it actually use memargs instead of hard-coded mem= value.
While at it fix sdboot command if initially booting U-Boot from NAND by
doing an explicit mmc part 0.
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
Common code has a mdelay() func, so use that instead of the usb-specific
wait_ms() func. This also fixes the build errors:
ohci-hcd.c: In function 'submit_common_msg':
/usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available
ohci-hcd.c:1519:9: sorry, unimplemented: called from here
ohci-hcd.c:1816:10: sorry, unimplemented: called from here
ohci-hcd.c:1827:10: sorry, unimplemented: called from here
ohci-hcd.c:1844:10: sorry, unimplemented: called from here
ohci-hcd.c:1563:11: sorry, unimplemented: called from here
ohci-hcd.c:1583:9: sorry, unimplemented: called from here
make[1]: *** [ohci-hcd.o] Error 1
All boards are using the gen_atmel_mci driver now, so no need
to carry the old driver around.
Signed-off-by: Sven Schnelle <svens@stackframe.org>
Boards can select either the 'built-in' parser or the hush parser. We
should not call builtin_run_command() if we are using the hush parser.
We use run_command() instead, since it knows how to call the correct
parser.
The current run_command() is only one of the parsing options - the other
is hush. We should not call run_command() when the hush parser is being
used. So we rename this function to better explain its purpose.
Signed-off-by: Thomas Weber <weber@corscience.de>
Mainline kernel for OMAP3 doesn't enable L2 cache
It expects L2$ to be enabled by ROM-code/bootloader.
Leaving L2$ enabled can be troublesome in cases where
the L2 cache is not under CP15 control, such as in
Cortex-A9. This problem is explained in detail in
the commit dc7100f4080952798413fb63bb4134b22c57623a
However, this problem doesn't apply to Cortex-A8
because L2$ in Cortex-A8 is under CP15 control and
hence the generic armv7 maintenance opertions work
for it.
As such we can make an exception for OMAP3 and
leave the L2$ enabled when we jump to kernel. This
is done by removing the strongly-linked implementation
of v7_outer_cache_disable() and allowing it to fall
back to the weakly linked implementation that doesn't
do anything.
Signed-off-by: Aneesh V <aneesh@ti.com>
davinci_dm6467Tevm
In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header
file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h.
The substantial difference between the davinci_dm6467evm and the
davinci_dm6467Tevm configuration is a single bit in the hardware revision
that is passed to the Linux kernel and davinci_dm6467evm has
REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a
REFCLK_FREQ = 33000000.
This patch removes include/configs/davinci_dm6467Tevm.h. Instead the
include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and
renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined
in boards.cfg.
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Tom Rini <trini@ti.com>
check for the return status for eth_getenv_enetaddr_by_index()
and eth_setenv_enetaddr() functions and print appropriate message
on failure.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
CONFIG_DISPLAY_CPUINFO is selected
get_reset_cause() function is only used inside print_cpuinfo(), so let it be
defined only when CONFIG_DISPLAY_CPUINFO is selected.
Cc: Detlev Zundel <dzu@denx.de>
Cc: Fabio Estevam <festevam@gmail.com>
This patch fixes booting i.MX28 CPUs via USB download.
In this mode the CPU's bootrom implements a USB HID device that
accepts a bootstream.
When downloading the bootstream via USB, first the SPL code is
received and executed. Then the u-boot image is received and
called.
The USB bootmode is interrupt driven.
This patch fixes two things:
1) The ARM's fast interrupt mode is disabled when the SPL code
has been run. So save and restore the CPSR register.
2) Save and restore c1 control register: the exception vector
location needs to be set back to bootrom space to make the USB
interrupts work again. The SPL code needs to change this
option for the ram size probing.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
The DC power STS shouldn't be checked if booting off 5V supply.
Cc: Robert Deliën <robert@delien.nl>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
commit f31a911fe (arm, post: add missing post_time_ms for arm)
enables get_ticks and get_tbclk for all arm based boards,
MX5/MX6 have not yet implemented.
CC: Dirk Behme <dirk.behme@de.bosch.com>
CC: Jason Liu <jason.hui@linaro.org>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Helmut Raiger <helmut.raiger@hale.at>
This patch moves hawkboard to the new spl infrastructure from the
older nand_spl one.
Removed the hawkboard_nand_config build option -- The spl code now
gets compiled with hawkboard_config, after building the main u-boot
image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard
to reflect the same.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Christian Riesch <christian.riesch@omicron.at>
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
The V bit of the c1 register of CP15 should not be cleared on DA850
SoCs since they have no valid memory at 0x00000000. This patch
introduces a configuration option CONFIG_SYS_EXCEPTION_VECTORS_HIGH
that allows setting the correct value for the V bit.
Reported-by: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Sughosh Ganu <urwithsughosh@gmail.com>
The current implementation invalidates the data cache before turning it
off and causes problems on the hawkboard. See the discussion in
http://lists.denx.de/pipermail/u-boot/2012-January/115212.html
According to the ARM926EJ-S Technical Reference Manual, the cache should
be flushed instead.
Also fix the comments to match code.
Rebased and corrected commit message.
This patch reverts commit ca4b55800ed74207c35271bf7335a092d4955416
"arm, arm926ejs: always do cpu critical inits" since it impacts all
arm926ejs based configurations and caused problems, e.g., with
the hawkboard.
Instead the patch removes the CONFIG_SKIP_LOWLEVEL_INIT defines
from the board configurations that need low level initialization.
The low level initialization code in
arch/arm/cpu/arm926ejs/davinci/lowlevel_init.S was written for
DM644X SoCs only. This patch makes the lowlevel_init function in this
file a dummy function for SoCs other than DM644X.
Cc: Sergey Kubushyn <ksi@koi8.net>
We do not have thermal management or Smartreflex
enabled at U-Boot level. So, it's better to stick
to OPP100 for MPU instead of the OPP Turbo that is
used now. Adjust the VDD_MPU accordingly.
Tested-by: Sebastien Jan <s-jan@ti.com>
add support for printing various clock frequency info found
in SOC such as ARM core frequency, DSP core frequency and DDR
frequency as part of bdinfo command.
remove the macro CONFIG_DISPLAY_CPUINFO as it is no longer
required. This is because clock info will be printed as part
'bdinfo' command and also remove support print_cpuinfo() as it will
no longer be called.
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
usb dpll configuration is done only part of non-essential
dppl configuration however if CONFIG_USB_EHCI_OMAP is defined
we may have to configure usb dpll's for proper functioning
of usb modules. So move the usb dppl configuration to a new func.
and utilise the same during essential dpll configuration.
Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Adding ehci clock enabling mechanism part of clock framework.
When essential clocks are enabled during init phase usb host
clocks can also be enabled from clock framework.
Samsung's ARM Cortex-A15 based SoCs are known as Exynos5 series of
SoCs. This patch adds the support for Exynos5.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
CONFIG_SYS_CLK_FREQ_C210 macro giving notion of S5PC2XX (Exynos4)
architecture. Replace CONFIG_SYS_CLK_FREQ_C210 with CONFIG_SYS_CLK_FREQ
to make it generic for exynos architecture.
This patch adds support the generic watchdog timer for s5pc1xx and exynos4
Cc: HeungJun, Kim <riverful.kim@samsung.com>
Earliar ARM clock frequency was calculated by:
MOUTAPLL/(DIVAPLL + 1) which is actually returning SCLKAPLL.
It is fixed by calculating it as follows:
ARMCLK=MOUTCORE / (DIVCORE + 1) / (DIVCORE2 + 1)
`get_ticks'
after http://patchwork.ozlabs.org/patch/136415/ was applied. All Marvell
build fails with below error
common/libcommon.o: In function `cread_line':
/home/uboot/src/u-boot-arm/common/main.c:717: undefined reference to `get_ticks'
/home/uboot/src/u-boot-arm/common/main.c:717: undefined reference to `get_tbclk'
/home/uboot/src/u-boot-arm/common/main.c:720: undefined reference to `get_ticks'
The same is fixed for Kirkwood, ARMADA100, pantheon and orion5x SoCs
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
The decompressor expects the L2 cache to be disabled. This fixes booting
some kernels, which have CONFIG_ARM_PATCH_PHYS_VIRT enabled.
Signed-off-by: Michael Walle <michael@walle.cc>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
FEC does not work on the i.mx51/53evk board, it will hangup
In: serial
Out: serial
Err: serial
Net:
After bisect, it due to the following commit:
be252b6 net: imx: Add multi-FEC support for imx_get_mac_from_fuse
has change the imx_get_mac_from_fuse fucntion prototype, but fail
to update i.mx5, here it does it.
After apply this patch, u-boot works again on i.mx51/53 evk boards.
Signed-off-by: Jason Liu <jason.hui@linaro.org>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
Showing CPU frequency during boot is useful information.
This patch modifies mxcmmc.c to be used
not only by i.MX27 but also by i.MX31 boards.
Both use the same SD controller, but have different
clock set-ups.
The i.MX27 imx_get_XXXclock functions are made static to
generic.c and a public mxc_get_clock() function
is provided. Pins, base address and prototypes for
an i.MX31 specific board_init_mmc() are provided.
Some of the i.MX27 clock getters are unused and marked
as such to avoid warnings (./MAKEALL -s mx27), but
the code was left in for future use.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
The Buffer Logic of VPSS is Not Reset by System Reset Pin, see
http://www.ti.com/lit/er/sprz316b/sprz316b.pdf chapter Advisory 1.2.1
on page 9. Add workaroundcode proposed in the errata.
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Tom Rini <tom.rini@gmail.com>
In 8775471bb, the call to timer_init() was removed from common code
and put in OMAP3 s_init() function. As a result the boot was broken
on OMAP4. This patch adds timer_init() in OMAP4 s_init(), that fix
boot on all OMAP4 boards.
Signed-off-by: Nicolas Dechesne <n-dechesne@ti.com>
Tested-by: Robert P. J. Day <rpjday@crashcourse.ca>
The function get_sdr_cs_offset reads the CS_CFG register in the SDRC
to determine where CS1 is mapped to. make_cs1_contiguous() will set
CS1 to follow after CS0. The CS_CFG register has values in bits 9:8
and 3:0 but we had erroneously been testing 5:4 and 3:0 resulting in
incorrect offsets on platforms with less than 128MB as 3:0 describe
128MB hunks and 9:8 describe 32MB offsets after the 128MB hunk.
Tested-by: Grant Erickson <marathon96@gmail.com>
Wrap the function save_boot_params with CONFIG_SPL_BUILD. This will
allow non-SPL boards to define their own save_boot_params functions
in U-Boot itself.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
The OMAP-L138 has a pre-divider available on PLL0.
Add support to da850_lowlevel.c for configuring PLL0's pre-divider. This is
to achieve certain OPP's -- e.g. the 372MHz OPP used also by Linux.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
CC: Heiko Schocher <hs@denx.de>
This enables the data cache on Tegra2 boards.
As discussed on the list, this is better off in the Tegra2 cpu code than in a
particular vendor directory. We should be safe turning on the cache for all
Tegra2 boards.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This adds support for SDMMC ports to the funcmux. Only one
option is supported: FUNCMUXO_SDMMC_8BIT which selects an 8-bit
wide SDIO interface where available.
Add support to funcmux for selecting I2C functions and programming
the pinmux appropriately.
We want to give a name to each available funcmux config. For now we just
use the pin group names (even through it is verbose) since there seems
to be nothing better.
We want to support config options other than zero, so move the test to the
end to allow intermediate code to OK such a config.
A value of 0 in the odmdata RAM size field means default, which is 512MB
not 1GB. Fix this. For reference, see:
http://nv-tegra.nvidia.com/gitweb/?p=linux-2.6.git;a=blob;\
f=arch/arm/mach-tegra/odm_kit/query/harmony/tegra_devkit_custopt.h;\
h=1ec7010911454f19a5018952fd245785a62c59ad;\
hb=0e52d7fe25b11a656c376a37890be219470661fb
v2: New patch
