path: root/arch/arm/cpu/tegra20-common
2013-04-15Tegra: Split tegra_get_chip_type() into soc & sku funcsTom Warren
As suggested by Stephen Warren, use tegra_get_chip() to return the pure CHIPID for a Tegra SoC (i.e. 0x20 for Tegra20, 0x30 for Tegra30, etc.) and rename tegra_get_chip_type() to reflect its true function, i.e. tegra_get_chip_sku(), which returns an ID like TEGRA_SOC_T25, TEGRA_SOC_T33, etc. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-15Tegra114: Initialize System Counter (TSC) with osc frequencyTom Warren
T114 needs the SYSCTR0 counter initialized so the TSC can be read by the kernel. Do it in the bootloader since it's a write-once deal (secure/non-secure mode dependent). Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-02-11tegra: rename FUNCMUX_UART2_UARTBStephen Warren
FUNCMUX_ defines should be named after the pin groups they affect, not after the module they're muxing onto those pin groups. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra: Move common clock code to arch/arm/cpu/tegra-common/clock.cTom Warren
This 'commonizes' much of the clock/pll code. SoC-dependent code and tables are left in arch/cpu/tegraXXX-common/clock.c Some T30 tables needed whitespace fixes due to checkpatch complaints. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16tegra: remove IRDA pinmux synonymAllen Martin
IRDA is a synonym for UARTB in tegra pinmux, remove all usage of this synonym and replace with UARTB to disambiguate. Signed-off-by: Allen Martin <amartin@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16Tegra30: Add common CPU (shared) filesTom Warren
These files are used by both SPL and main U-Boot. Also made minor changes to shared Tegra code to support T30 differences. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-11-19tegra: Add display support to funcmuxSimon Glass
Add support for a default pin mapping for display1. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Use const for pinmux_config_pingroup/table()Simon Glass
These two functions don't actually modify their arguments so add a const keyword. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29tegra20: initialize variable to avoid compiler warningAllen Martin
Initialize this variable to avoid a compiler warning about possible use of uninitialized variable with gcc 4.4.6. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra: add funcmux entry for NAND attached to KBCLucas Stach
Secondary config for the Flash attachment. Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra20: add clock_set_pllout functionLucas Stach
Common practice on Tegra 2 boards is to use the pllp_out4 FO to generate the ULPI reference clock. For this to work we have to override the default hardware generated output divider. This function adds a clean way to do so. Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra20: complete periph_id enumLucas Stach
Most Tegra boards output the ULPI reference clock on pad DEV2. Complete the periph_id enum so that we are able to enable this clock output circuit. Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15Tegra20: Move some code files to common directories for upcoming Tegra30 ↵Tom Warren
patches. Move files that are going to be common between T20 and T30 into 'tegra-common' subdirs in AVP (arm720t), CPU (armv7), and shared (arch/arm/cpu/.) areas. Any files that are left behind in '/tegra20' will be copied to '/tegra30' subdirs and modified for that SoC. The 'common' files should need only minor changes. Include files (arch/arm/include/asm/arch-tegra/tegra20) will be done in a follow-on patch. Builds fine w/MAKEALL -s tegra20. Checkpatch.pl is clean. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-07tegra: Add NAND support to funcmuxSimon Glass
Add selection of NAND flash pins to the funcmux. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: Remove armv4t build flagsAllen Martin
These flags were necessary when building tegra20 as a single binary that supported ARM7TDMI and Cortex A9. Now that the ARM7TDMI support is split into a separate SPL, this is no longer necessary. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: enable SPL for tegra20 boardsAllen Martin
Add SPL options to tegra20 config files and enable SPL build for tegra20 boards. Also remove redundant code from u-boot that is not contained in SPL. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: move SDRAM param save to later in bootAllen Martin
Move warmboot_save_sdram_params() to later in the boot sequence. This code relies on devicetree to get the address of the memory controller and with upcoming changes for SPL boot it gets called early in the boot process when devicetree is not initialized yet. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: move tegra20 SoC code to arch/arm/cpu/tegra20-commonAllen Martin
In preparation for splitting out the armv4t code from tegra20, move the tegra20 SoC code to arch/arm/cpu/tegra20-common. This code will be compiled armv4t for the arm7tdmi and armv7 for the cortex A9. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
