path: root/arch/arm/cpu/tegra20-common/crypto.c
2014-04-18ARM:tegra20: Remove aes debug printsTom Rini
In 6e7b9f4 some of the debug prints for AES code moved into the generic code, so we remove these additional calls. Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Tom Warren <twarren@nvidia.com>
2014-04-18aes: make apply_cbc_chain_data non-staticStephen Warren
Tegra's crypto.c uses apply_cbc_chain_data() to sign the warm restart code. This function was recently moved into the core aes.c and made static, which prevents the Tegra code from compiling. Make it public again to avoid the compile errors: arch/arm/cpu/tegra20-common/crypto.c: In function ‘sign_object’: arch/arm/cpu/tegra20-common/crypto.c:74:3: warning: implicit declaration of function ‘apply_cbc_chain_data’ [-Wimplicit-function-declaration] arch/arm/cpu/built-in.o: In function `sign_object': .../arch/arm/cpu/tegra20-common/crypto.c:74: undefined reference to `apply_cbc_chain_data' .../arch/arm/cpu/tegra20-common/crypto.c:78: undefined reference to `apply_cbc_chain_data' Fixes: 6e7b9f4fa0ae ("aes: Move the AES-128-CBC encryption function to common code") Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2014-03-21aes: Move the AES-128-CBC encryption function to common codeMarek Vasut
Move the AES-128-CBC encryption function implemented in tegra20-common/crypto.c into lib/aes.c . This is well re-usable common code. Moreover, clean the code up a bit and fix the kerneldoc-style annotations. Signed-off-by: Marek Vasut <marex@denx.de>
2012-09-01tegra20: move tegra20 SoC code to arch/arm/cpu/tegra20-commonAllen Martin
In preparation for splitting out the armv4t code from tegra20, move the tegra20 SoC code to arch/arm/cpu/tegra20-common. This code will be compiled armv4t for the arm7tdmi and armv7 for the cortex A9. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
